Saltar al contenido principal
Nerf Zombie Strike Crossbow Trigger Spring Replacement
Qué necesitas
  1. Nerf Zombie Strike Crossbow Trigger Spring Replacement, Trigger Spring: paso 1, imagen 1 de 1
    • There are 19 1.0 cm screws in total.
  2. Nerf Zombie Strike Crossbow Trigger Spring Replacement: paso 2, imagen 1 de 1
    • Separate each part of the Nerf crossbow.
  3. Nerf Zombie Strike Crossbow Trigger Spring Replacement: paso 3, imagen 1 de 1
    • Use the screwdriver and unscrew each screw one-by-one placing each screw on the magnetic mat to insure they do not get lost.
  4. Nerf Zombie Strike Crossbow Trigger Spring Replacement: paso 4, imagen 1 de 1
    • Take the broken spring off of the trigger.
  5. Nerf Zombie Strike Crossbow Trigger Spring Replacement: paso 5, imagen 1 de 1
    • Replace it with the new spring you bought at your local hardware store.
  6. Nerf Zombie Strike Crossbow Trigger Spring Replacement: paso 6, imagen 1 de 1
    • Now that the spring has been reattached to the trigger repeat step two.
    • Finish by performing steps two and three in reverse order.
Conclusión
Una persona más ha completado esta guía.
Benjamin Bucklin
Miembro Desde 10/09/14
61 Reputación
3 Guías creadas
Equipo
Un comentario
how do you get the arms/wings off without damaging the lock on clip?
Coventeena - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 3,623
