Saltar al contenido principal
Nerf Zombie Strike Crossbow Plunger Replacement
Qué necesitas
  1. Nerf Zombie Strike Crossbow Plunger Replacement, Plunger: paso 1, imagen 1 de 1
    • There are 19 1.0 cm screws.
  2. Nerf Zombie Strike Crossbow Plunger Replacement: paso 2, imagen 1 de 1
    • Use the screwdriver and unscrew each screw one-by-one placing each screw on the magnetic mat to insure they do not get lost.
  3. Nerf Zombie Strike Crossbow Plunger Replacement: paso 3, imagen 1 de 1
    • Separate each part of the Nerf crossbow.
  4. Nerf Zombie Strike Crossbow Plunger Replacement, Removing the Plunger for Inspection: paso 4, imagen 1 de 1
    • Carefully remove the plunger from the chamber for inspection.
  5. Nerf Zombie Strike Crossbow Plunger Replacement: paso 5, imagen 1 de 1
    • Check to make sure the plunger is intact and has the the rubber stopper at the end of it.
    • Also make sure the spring is intact and is not bent.
    • If the spring is bent you can purchase one similar to it at a local hardware store.
  6. Nerf Zombie Strike Crossbow Plunger Replacement: paso 6, imagen 1 de 1
    • Make sure that plunger is reattached to the cocking mechanism.
  7. Nerf Zombie Strike Crossbow Plunger Replacement: paso 7, imagen 1 de 1
    • Check chamber to make sure that there are no holes or cracks.
    • If there are holes or crakes then the problem will not be able to be resolved since Nerf does not sell these types of parts.
Conclusión
Una persona más ha completado esta guía.
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 2,368
