Saltar al contenido principal
Nerf Zombie Strike Crossbow Cocking Mechanism Replacement
Qué necesitas
  1. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement, Cocking Mechanism: paso 1, imagen 1 de 1
    • There are 19 1.0 cm screws.
  2. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: paso 2, imagen 1 de 1
    • The cocking device air to be built up inside the Nerf crossbow, which generates the force needed to propel the darts.
  3. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: paso 3, imagen 1 de 1
    • Use the screwdriver and unscrew each screw one-by-one placing each screw on the magnetic mat to insure they do not get lost.
  4. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: paso 4, imagen 1 de 1
    • Separate each part of the Nerf crossbow.
  5. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: paso 5, imagen 1 de 1
    • Make sure the cocking mechanism is properly aligned with the rest of the Nerf crossbow.
  6. Nerf Zombie Strike Crossbow Cocking Mechanism Replacement: paso 6, imagen 1 de 1
    • The cocking device needs to be attached to the plunger in order to function properly.
Conclusión
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 10
Todo El Tiempo: 3,469
