Introducción
This guide will show how to remove the entire barrel and pump assembly for replacement or repair. A screwdriver with a long shaft will be needed to get to all of the screws. Also watch out for any small parts that may come apart and fall out as you're working on the device.
Qué necesitas
Start by taking out all of the screws for the casing of the gun. Using the PH #00 screwdriver, unscrew all four 1.3-cm screws in the pump.
Casi Terminas!
Conclusión
