Saltar al contenido principal
Nerf N-Strike Maverick Trigger Repair
Qué necesitas
  1. Nerf N-Strike Maverick Trigger Repair, Nerf N-Strike Maverick Trigger Repair: paso 1, imagen 1 de 1
    • Remove the 10 screws on the outer shell of the Maverick.
    • Make sure to keep all the screws in a cup or container so they don't get lost.
  2. Nerf N-Strike Maverick Trigger Repair: paso 2, imagen 1 de 2 Nerf N-Strike Maverick Trigger Repair: paso 2, imagen 2 de 2
    • After removing all of the screws, slowly lift the gray top left piece.
    • The other side of the top left piece can also be taken off.
  3. Nerf N-Strike Maverick Trigger Repair: paso 3, imagen 1 de 1
    • Remove the top left screw.
  4. Nerf N-Strike Maverick Trigger Repair: paso 4, imagen 1 de 2 Nerf N-Strike Maverick Trigger Repair: paso 4, imagen 2 de 2
    • While holding the Maverick down slowly lift the outer shell.
    • Make sure the orientation of the Maverick matches the picture shown.
  5. Nerf N-Strike Maverick Trigger Repair: paso 5, imagen 1 de 2 Nerf N-Strike Maverick Trigger Repair: paso 5, imagen 2 de 2
    • Remove the screw holding the trigger to the body.
    • When screwing everything back together, remember to re hook the trigger spring.
  6. Nerf N-Strike Maverick Trigger Repair: paso 6, imagen 1 de 3 Nerf N-Strike Maverick Trigger Repair: paso 6, imagen 2 de 3 Nerf N-Strike Maverick Trigger Repair: paso 6, imagen 3 de 3
    • Check the inner chassis around the trigger area. Make sure the springs and parts can move freely.
    • If a part is broken, a replacement will need to be bought or taken from another Maverick.
  7. Nerf N-Strike Maverick Trigger Repair: paso 7, imagen 1 de 2 Nerf N-Strike Maverick Trigger Repair: paso 7, imagen 2 de 2
    • After examining and fixing the chassis, screw the trigger back onto the body.
    • Hook the upper spring to the metal rod.
  8. Nerf N-Strike Maverick Trigger Repair: paso 8, imagen 1 de 3 Nerf N-Strike Maverick Trigger Repair: paso 8, imagen 2 de 3 Nerf N-Strike Maverick Trigger Repair: paso 8, imagen 3 de 3
    • Replace the outer shell of the Maverick and the top left screw.
    • When reattaching the outer shell, make sure to hold the top left piece as shown in the first picture. This ensures that the spring remains connected to the rod.
    • Screw the top left piece back onto the Maverick.
    • Replace the 10 screws on the Maverick.
Linea de Meta
2 personas más completaron esta guía.
David Lim
Miembro Desde 09/27/15
137 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 10-3, Green Fall 2015 Miembro de Cal Poly, Team 10-3, Green Fall 2015
CPSU-GREEN-F15S10G3
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 14
Todo El Tiempo: 2,261
