Saltar al contenido principal
Nerf N-Strike Maverick Catch Spring Replacement
Qué necesitas
  1. Nerf N-Strike Maverick Catch Spring Replacement, Use the Teardown Guide to Open the Gun: paso 1, imagen 1 de 1
  2. Nerf N-Strike Maverick Catch Spring Replacement, Remove Large Spring: paso 2, imagen 1 de 1
    • Remove the larger spring from the catch mechanism.
  3. Nerf N-Strike Maverick Catch Spring Replacement, Remove the Catch Mechanism & Spring: paso 3, imagen 1 de 1
    • Remove the catch mechanism and spring by gently lifting it straight up and off the metal pin that holds it.
    • The catch spring has a tendency to bounce away when removed.
  4. Nerf N-Strike Maverick Catch Spring Replacement, Replace the Catch Spring: paso 4, imagen 1 de 1
    • After removing the old catch spring, place the new catch spring back on the tip of the catch mechanism.
    • If you are unable to find an exact replacement, one may be fashioned out of a pen spring.
  5. Nerf N-Strike Maverick Catch Spring Replacement, Putting the Catch Mechanism Back: paso 5, imagen 1 de 1
    • Carefully replace the catch mechanism so that it is seated in the grooves and over the metal pin.
Conclusión
4 personas más completaron esta guía.
Equipo
Un comentario
do you have a spare catch spring the whole catch mechanism and spring
cowboybebop6968 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 44
Todo El Tiempo: 7,206
