Introducción
My modified Nerf Longshot (nicknamed: Leviathan) is a significant powerhouse compared to most stock foam dart blasters. Although I have yet to measure the muzzle velocity of the Leviathan, I can visually notice double the muzzle velocity compared to stock nerf blasters, at least 140 feet per second (FPS) versus 70 FPS. The reason for a high FPS comes down to a powerful spring pushing a plunger forward in an airtight tube to force air into the firing chamber where the dart lies, propelling the dart through an airtight inner barrel for a high muzzle velocity. However, the plunger needs an O-ring as an air seal, and worn-out O-rings will slip off the plunger, disabling the blaster. I will show you how to replace the O-ring in this guide.
Qué necesitas
You can tell the blaster is not primed when the spring pushes the front pump handle or side handle.
If the blaster is primed, you can release the spring tension by pulling the trigger.
With all maintenance completed, the Leviathan is back on the hunt. Good hunting, Nerf snipers.
