Saltar al contenido principal
Nerf N-Strike Firestrike Wire Replacement
Qué necesitas
  1. Nerf N-Strike Firestrike Wire Replacement, Remove battery cover: paso 1, imagen 1 de 1
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
  2. Nerf N-Strike Firestrike Wire Replacement: paso 2, imagen 1 de 2 Nerf N-Strike Firestrike Wire Replacement: paso 2, imagen 2 de 2
    • Slide out the two AAA batteries using your fingers.
  3. Nerf N-Strike Firestrike Wire Replacement, Blaster Casing: paso 3, imagen 1 de 1
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
  4. Nerf N-Strike Firestrike Wire Replacement: paso 4, imagen 1 de 2 Nerf N-Strike Firestrike Wire Replacement: paso 4, imagen 2 de 2
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
  5. Nerf N-Strike Firestrike Wire Replacement: paso 5, imagen 1 de 2 Nerf N-Strike Firestrike Wire Replacement: paso 5, imagen 2 de 2
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
  6. Nerf N-Strike Firestrike Wire Replacement, Firing Trigger: paso 6, imagen 1 de 2 Nerf N-Strike Firestrike Wire Replacement, Firing Trigger: paso 6, imagen 2 de 2
    • Remove the firing trigger by grabbing the trigger with your fingers and pulling it up and out.
  7. Nerf N-Strike Firestrike Wire Replacement, Laser Trigger: paso 7, imagen 1 de 2 Nerf N-Strike Firestrike Wire Replacement, Laser Trigger: paso 7, imagen 2 de 2
    • Remove the laser trigger by grabbing the trigger with your fingers and pulling it up and out.
  8. Nerf N-Strike Firestrike Wire Replacement, Laser Assembly: paso 8, imagen 1 de 1
    • Gently pull up on the circuit board located near the gun handle until it separates from the gun.
    • The wire that attaches to the circuit board is also attached to the laser. Be careful not to use excessive force and damage or disconnect the wire.
  9. Nerf N-Strike Firestrike Wire Replacement: paso 9, imagen 1 de 3 Nerf N-Strike Firestrike Wire Replacement: paso 9, imagen 2 de 3 Nerf N-Strike Firestrike Wire Replacement: paso 9, imagen 3 de 3
    • Grip the circuit board located at the base of the laser with your fingers; rotate it towards the ammo compartment on the blaster until the guide hole is clear of the guide pin.
    • Slide the laser assembly out.
  10. Nerf N-Strike Firestrike Wire Replacement, Wire: paso 10, imagen 1 de 2 Nerf N-Strike Firestrike Wire Replacement, Wire: paso 10, imagen 2 de 2
    • Pinch the clips holding the circuit board to the laser assembly and remove the circuit board.
  11. Nerf N-Strike Firestrike Wire Replacement: paso 11, imagen 1 de 1
    • Desolder the wires from the circuit board.
    • The positive wire is attached at the lower left, while the negative wire is attached at the middle of the bottom.
  12. Nerf N-Strike Firestrike Wire Replacement: paso 12, imagen 1 de 2 Nerf N-Strike Firestrike Wire Replacement: paso 12, imagen 2 de 2
    • Use a soldering iron to melt the solder attaching the wires to the circuit board.
    • The positive lead is attached at the middle right of the board, while the negative lead is attached at the bottom right of the board.
Conclusión
Una persona más ha completado esta guía.
Hayes Kimball
Miembro Desde 04/19/15
742 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 15-6, Amido Spring 2015 Miembro de Cal Poly, Team 15-6, Amido Spring 2015
CPSU-AMIDO-S15S15G6
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 781
