Saltar al contenido principal
Introducción
This guide will walk you through opening your Nerf N-Strike Firestrike and removing the firing trigger. Many screws must be removed before opening the casing so be careful not to misplace any.
After the casing is removed and the Nerf gun is opened, you will see two triggers near the lower portion of the gun. The larger of the two triggers is the firing trigger and this is what you will be removing. Just grab it from the side with two fingers and pull straight up to remove the firing trigger.
Partes
No se especificaron partes.
  1. Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
    • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
  2. Slide out the two AAA batteries using your fingers. Slide out the two AAA batteries using your fingers.
    • Slide out the two AAA batteries using your fingers.
  3. Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
    • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
  4. Slowly pull apart the blaster casing, starting at the battery location. Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
    • Slowly pull apart the blaster casing, starting at the battery location.
    • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
  5. For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box. For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
    • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
    • For reassembly, note the location of the springs as highlighted in the second photo.
  6. Remove the firing trigger by grabbing the trigger with your fingers and pulling it up and out. Remove the firing trigger by grabbing the trigger with your fingers and pulling it up and out.
    • Remove the firing trigger by grabbing the trigger with your fingers and pulling it up and out.
Conclusión
4 personas más completaron esta guía.
Jong Wan Kim
Miembro Desde 22/04/15
422 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 15-6, Amido Spring 2015 Miembro de Cal Poly, Team 15-6, Amido Spring 2015
CPSU-AMIDO-S15S15G6
3 Miembros
8 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 2,523
