Qué necesitas
Locate the trigger mechanism's assembly, and notice that it's held in place by a single philip's head screw. Remove it.
Screw specifications: Philips head, Head Diameter= 4.3mm, Thread Pitch= 1mm, Screw Length= 8mm
Inspect the orange parts for signs of damage and debris. Any broken pieces must be replaced.
This is the spring that controls the trigger. Through regular use, the spring may become mangled or damaged. If it becomes damaged, a spring from a ballpoint pen can function as a decent replacement.
9 personas más completaron esta guía.
