Saltar al contenido principal
Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement
Qué necesitas
  1. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement, Springs: paso 1, imagen 1 de 2 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement, Springs: paso 1, imagen 2 de 2
    • Remove three screws with a Phillips #1 screwdriver.
    • Remove the pump grip.
  2. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: paso 2, imagen 1 de 1
    • Remove thirteen highlighted screws using a Phillips #1 screwdriver.
    • The top rail has shorter screws than the rest.
    • Some of these are captive screws and cannot be removed.
  3. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: paso 3, imagen 1 de 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: paso 3, imagen 2 de 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: paso 3, imagen 3 de 3
    • Remove the backside by sliding the plastic spudger across the seam.
    • There are loose parts that can fall out. Take these off and put them aside.
  4. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: paso 4, imagen 1 de 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: paso 4, imagen 2 de 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: paso 4, imagen 3 de 3
    • Separate the trigger mechanism from the barrel.
  5. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: paso 5, imagen 1 de 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: paso 5, imagen 2 de 3 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: paso 5, imagen 3 de 3
    • Remove the plunger springs from the mechanism by pulling one of the springs back then bending it off the connection.
    • These are tricky to remove, so be careful when pulling them off.
  6. Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: paso 6, imagen 1 de 2 Nerf N-Strike Elite Rough Cut 2x4 Springs Replacement: paso 6, imagen 2 de 2
    • Now pull the springs out and add new ones.
    • There are a few pieces with springs that can misalign in reassembly. Keep in mind where they are.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 44
Todo El Tiempo: 2,942
