Saltar al contenido principal
Nerf N-Strike Elite Retaliator Spring Replacement
Qué necesitas
  1. Nerf N-Strike Elite Retaliator Spring Replacement, Case Disassembly: paso 1, imagen 1 de 1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator Spring Replacement: paso 2, imagen 1 de 1
    • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
  3. Nerf N-Strike Elite Retaliator Spring Replacement: paso 3, imagen 1 de 1
    • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
  4. Nerf N-Strike Elite Retaliator Spring Replacement: paso 4, imagen 1 de 2 Nerf N-Strike Elite Retaliator Spring Replacement: paso 4, imagen 2 de 2
    • Remove the stock attachment point by removing the two 8mm Phillips head screws.
  5. Nerf N-Strike Elite Retaliator Spring Replacement: paso 5, imagen 1 de 2 Nerf N-Strike Elite Retaliator Spring Replacement: paso 5, imagen 2 de 2
    • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
    • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
    • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
  6. Nerf N-Strike Elite Retaliator Spring Replacement, Remove Old Firing Spring: paso 6, imagen 1 de 2 Nerf N-Strike Elite Retaliator Spring Replacement, Remove Old Firing Spring: paso 6, imagen 2 de 2
    • The spring may be compressed. If so, carefully release spring pressure before proceeding.
    • While holding down the white Plunger tube, pull the spring backwards to remove it from the blaster.
Conclusión
11 personas más completaron esta guía.
ericharman
Miembro Desde 03/02/16
1,410 Reputación
5 Guías creadas
2 comentarios
how do I remove the screws that you have to pull back the sliding mechanism if it cant be pulled back
Ryan Zhang - Contestar
can i use a nerf kronos spring
jordan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 32
Todo El Tiempo: 12,577
