Saltar al contenido principal
Nerf N-Strike Elite Retaliator Barrel Replacement
Qué necesitas
  1. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Barrel: paso 1, imagen 1 de 1
    • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
  2. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Grip: paso 2, imagen 1 de 1
    • Slide the hand grip assembly toward the end of the barrel and off the barrel assembly.
    • This may require more force than anticipated.
  3. Nerf N-Strike Elite Retaliator  Barrel Replacement, Remove Barrel Cap: paso 3, imagen 1 de 1
    • Disassemble the orange barrel cap by removing two 8mm Phillips screws.
  4. Nerf N-Strike Elite Retaliator  Barrel Replacement, Disassemble Barrel Assembly: paso 4, imagen 1 de 1
    • Disassemble the barrel assembly by removing four 8mm Phillips screws from the blue barrel housing.
    • There are springs that may become displaced when the barrel housing is removed. Proceed with caution.
  5. Nerf N-Strike Elite Retaliator  Barrel Replacement, Replace Barrel: paso 5, imagen 1 de 1
    • Remove the orange barrel from the assembly.
Conclusión
6 personas más completaron esta guía.
ericharman
Miembro Desde 03/02/16
1,410 Reputación
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 23
Todo El Tiempo: 11,376
