Saltar al contenido principal
Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement
Qué necesitas
  1. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Left Shell: paso 1, imagen 1 de 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Left Shell: paso 1, imagen 2 de 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Left Shell: paso 1, imagen 3 de 3
    • Before disassembling your Nerf Hail-Fire, be sure to remove the batteries.
    • Remove the two 9.0 mm Phillips screws securing the battery compartment.
    • Slide the battery compartment out.
  2. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 2, imagen 1 de 1
    • Remove the five 9.0 mm Phillips screws securing the trigger.
  3. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 3, imagen 1 de 2 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 3, imagen 2 de 2
    • Remove the single 11.0 mm Phillips screw securing the magazine cartridge chambers.
    • Pull the entire chamber upwards to separate it from the rest of the Nerf Gun.
  4. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 4, imagen 1 de 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 4, imagen 2 de 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 4, imagen 3 de 3
    • Remove both halves of the ring by tugging on it upwards until the lock gets freed.
    • This requires quite a bit of force and if you are not careful, you may break the plastic lock.
  5. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 5, imagen 1 de 1
    • Remove the four 9.0 mm Phillips screws from the newly revealed cylinder.
  6. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 6, imagen 1 de 1
    • Remove the three 9.0 mm Phillips screws holding the top latch of the Nerf Gun together.
  7. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 7, imagen 1 de 1
    • Remove the three 9.0 mm Phillips screws holding together the firing chamber.
    • Remove the single 7.0 mm Phillips screw below the barrel.
    • Remove the two 14.0 mm Philips screws using a screwdriver with a length of approximately 4.0 inches and a diameter of approximately 0.2 cm.
  8. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 8, imagen 1 de 1
    • Remove the single 14.0 mm Phillips screw holding together the handle and the Nerf Gun.
  9. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 9, imagen 1 de 2 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 9, imagen 2 de 2
    • Remove the two 9.0 mm Phillips screws holding together the handle.
    • Remove the plastic cover of the handle.
  10. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 10, imagen 1 de 2 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 10, imagen 2 de 2
    • Insert one plastic opening tool inside one side of the orange part depicted in the picture.
    • Insert a second plastic opening tool to the other side of the orange part and gradually pull the piece out, freeing it from the handle.
  11. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 11, imagen 1 de 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 11, imagen 2 de 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 11, imagen 3 de 3
    • Pull one end of the handle away from the orange latch.
    • Repeat the procedure on the other side to completely remove the handle from the rest of the Nerf Gun.
  12. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 12, imagen 1 de 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 12, imagen 2 de 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 12, imagen 3 de 3
    • Lift the entire left shell slowly. The process should be easy and if there is any resistance, there is something wrong. You may have forgotten a screw.
    • Completely remove the left shell from the rest of the Nerf Gun.
  13. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Inner Plastic Components: paso 13, imagen 1 de 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Inner Plastic Components: paso 13, imagen 2 de 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Inner Plastic Components: paso 13, imagen 3 de 3
    • Remove the cartridge support.
  14. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 14, imagen 1 de 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 14, imagen 2 de 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 14, imagen 3 de 3
    • Remove the handle crank.
  15. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 15, imagen 1 de 2 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 15, imagen 2 de 2
    • Remove the clear plastic barrel cover.
  16. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 16, imagen 1 de 2 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: paso 16, imagen 2 de 2
    • Remove the firing pin.
Conclusión
Una persona más ha completado esta guía.
sage
Miembro Desde 01/24/14
301 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 13-13, Regan Winter 2014 Miembro de Cal Poly, Team 13-13, Regan Winter 2014
CPSU-REGAN-W14S13G13
4 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 1,200
