Saltar al contenido principal
Nerf N-Strike Elite Hail-Fire Battery Replacement
Qué necesitas
  1. Nerf N-Strike Elite Hail-Fire Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the two 9.0 mm Phillips screws from the battery compartment.
  2. Nerf N-Strike Elite Hail-Fire Battery Replacement: paso 2, imagen 1 de 1
    • Pull the battery compartment out and away from the gun.
  3. Nerf N-Strike Elite Hail-Fire Battery Replacement: paso 3, imagen 1 de 1
    • Apply downwards pressure on the battery you're trying to remove in the direction of the spring.
  4. Nerf N-Strike Elite Hail-Fire Battery Replacement: paso 4, imagen 1 de 1
    • Pull battery straight out. Do not throw used batteries in the trash! Please electronically recycle them properly.
  5. Nerf N-Strike Elite Hail-Fire Battery Replacement: paso 5, imagen 1 de 1
    • When installing new batteries, ensure that their polarities are facing the correct directions. Follow the inscriptions on the bottom of the battery tray, or place the flat side of each battery against the spring.
Conclusión
6 personas más completaron esta guía.
Jonathan Peck
Miembro Desde 01/24/14
217 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 13-13, Regan Winter 2014 Miembro de Cal Poly, Team 13-13, Regan Winter 2014
CPSU-REGAN-W14S13G13
4 Miembros
7 Guías creadas
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 18
Ultimos 30 días: 83
Todo El Tiempo: 25,859
