Saltar al contenido principal
Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement
Qué necesitas
  1. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Notes Before Starting: paso 1, imagen 1 de 1
    • There are many screws of varying lengths involved in the disassembling of this device. It is important to keep track which screws correspond to which holes. This will help ensure proper reassembly.
    • Be sure that the rifle is discharged and unloaded before starting disassembly.
  2. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Rear Cap Removal: paso 2, imagen 1 de 3 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Rear Cap Removal: paso 2, imagen 2 de 3 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Rear Cap Removal: paso 2, imagen 3 de 3
    • Looking from the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
    • Pull off the orange cap.
  3. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Slide Removal: paso 3, imagen 1 de 3 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Slide Removal: paso 3, imagen 2 de 3 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Slide Removal: paso 3, imagen 3 de 3
    • With the rifle barrel pointing left, remove the two 8mm phillips screws holding the slide mechanism together.
    • Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
    • Separate and remove the two halves of the slide mechanism.
    • Make sure to keep track of which screws correspond to which holes.
  4. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: paso 4, imagen 1 de 2 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: paso 4, imagen 2 de 2
    • Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle.
    • Remove the two 5 mm phillips screws from the main body.
    • Remove the two 8 mm phillips screws from the main body.
    • Screws are varying lengths, make sure to keep track of which screws correspond to which holes.
  5. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: paso 5, imagen 1 de 3 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: paso 5, imagen 2 de 3 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: paso 5, imagen 3 de 3
    • Pull the two halves of the rifle apart.
    • Be careful of the spring at the rear end of the rifle. It may come flying out.
    • If you have difficulty pulling the two halves apart, spudger to gently pry the edges of the body apart.
    • Also be careful of small parts when opening the gun, they may be easy to lose.
    • Remove the access gate and barrel cover.
  6. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Spring Removal: paso 6, imagen 1 de 1
    • You should now be able to pull the main firing spring from the rear of the rifle.
  7. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Hammer Rod: paso 7, imagen 1 de 2 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement, Hammer Rod: paso 7, imagen 2 de 2
    • Remove the two 5 mm phillips screws holding the muzzle in place.
  8. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: paso 8, imagen 1 de 1
    • Remove the barrel and muzzle assembly from the gun body.
  9. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: paso 9, imagen 1 de 2 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: paso 9, imagen 2 de 2
    • Remove the 5mm phillips screw holding in the chamber lock mechanism.
  10. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: paso 10, imagen 1 de 2 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: paso 10, imagen 2 de 2
    • Pull the front chamber lock spring up and out of its seat.
    • Pull the front chamber lock mechanism down and out of the rifle barrel.
    • Note there are two pieces to this mechanism.
  11. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: paso 11, imagen 1 de 3 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: paso 11, imagen 2 de 3 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: paso 11, imagen 3 de 3
    • Holding the rear chamber slide lock down, slide the chamber to the rear of the rifle.
    • Remove the rear section of the barrel.
  12. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: paso 12, imagen 1 de 1
    • With the plunger in the air cylinder, pull the plunger lock out of the rifle body.
  13. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: paso 13, imagen 1 de 1
    • Pull the air cylinder and plunger assembly rearwards and out of the rifle.
  14. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: paso 14, imagen 1 de 1
    • While holding the slide lock mechanism down, pull the bullet chamber assembly up and out of the rifle.
    • Part of the magazine lock mechanism should come along with it.
  15. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: paso 15, imagen 1 de 2 Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: paso 15, imagen 2 de 2
    • With the hammer rod side of the bullet chamber facing you, unscrew the 5 mm phillips screw holding the hammer rod in place.
  16. Nerf N-Strike Elite Alpha Trooper CS-12 Hammer Rod Replacement: paso 16, imagen 1 de 1
    • Remove the hammer rod.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 10-35, Maness Winter 2014 Miembro de Cal Poly, Team 10-35, Maness Winter 2014
CPSU-MANESS-W14S10G35
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 7,507
