Saltar al contenido principal
Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement
Qué necesitas
  1. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Rear Cap Removal: paso 1, imagen 1 de 3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Rear Cap Removal: paso 1, imagen 2 de 3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Rear Cap Removal: paso 1, imagen 3 de 3
    • Looking from the rear of the rifle, remove the two 10 mm phillips screws holding the orange cap to the butt of the rifle.
    • Pull off the orange cap.
  2. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Slide Removal: paso 2, imagen 1 de 3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Slide Removal: paso 2, imagen 2 de 3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement, Slide Removal: paso 2, imagen 3 de 3
    • With the rifle barrel pointing left, remove the two 8 mm phillips screws holding the slide mechanism together.
    • Remove the three 10 mm phillips screws from the bottom of the slide mechanism.
    • Separate and remove the two halves of the slide mechanism.
    • Make sure to keep track of which screws correspond to which holes.
  3. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: paso 3, imagen 1 de 2 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: paso 3, imagen 2 de 2
    • Again with the rifle barrel pointing left, remove the fourteen 10 mm phillips screws from the main body of the rifle.
    • Remove the two 5 mm phillips screws from the main body.
    • Remove the two 8 mm phillips screws from the main body.
    • Screws are varying lengths, make sure to keep track of which screws correspond to which holes.
  4. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: paso 4, imagen 1 de 3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: paso 4, imagen 2 de 3 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: paso 4, imagen 3 de 3
    • Pull the two halves of the rifle apart.
    • Be careful of the spring at the rear end of the rifle. It may come flying out.
    • If you have difficulty pulling the two halves apart, use a spudger to gently pry the edges of the body apart.
    • Also be careful of small parts when opening the gun, they may be easy to lose.
    • Remove the access gate and barrel cover.
  5. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: paso 5, imagen 1 de 2 Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: paso 5, imagen 2 de 2
    • Remove the two 5mm phillips screws from the rifle muzzle.
  6. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: paso 6, imagen 1 de 1
    • Remove the muzzle and barrel from the rifle body.
  7. Nerf N-Strike Elite Alpha Trooper CS-12 Barrel Replacement: paso 7, imagen 1 de 1
    • Separate the muzzle from the barrel.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 10-35, Maness Winter 2014 Miembro de Cal Poly, Team 10-35, Maness Winter 2014
CPSU-MANESS-W14S10G35
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 10
Todo El Tiempo: 5,869
