Saltar al contenido principal
Nerf Mega Magnus Spring Replacement
Qué necesitas
  1. Nerf Mega Magnus Spring Replacement, Spring: paso 1, imagen 1 de 3 Nerf Mega Magnus Spring Replacement, Spring: paso 1, imagen 2 de 3 Nerf Mega Magnus Spring Replacement, Spring: paso 1, imagen 3 de 3
    • Start by removing the (4) exterior Phillips screws from the shell of the gun with a #1 Phillips Screwdriver.
  2. Nerf Mega Magnus Spring Replacement: paso 2, imagen 1 de 2 Nerf Mega Magnus Spring Replacement: paso 2, imagen 2 de 2
    • Pulling upward from the rest of the shell, carefully remove the half of the slide facing you.
  3. Nerf Mega Magnus Spring Replacement: paso 3, imagen 1 de 3 Nerf Mega Magnus Spring Replacement: paso 3, imagen 2 de 3 Nerf Mega Magnus Spring Replacement: paso 3, imagen 3 de 3
    • On the same side, remove all (9) screws from the body of the blaster as shown.
  4. Nerf Mega Magnus Spring Replacement: paso 4, imagen 1 de 2 Nerf Mega Magnus Spring Replacement: paso 4, imagen 2 de 2
    • Lift up on the top half of the shell with deliberate force. This should reveal the internals.
  5. Nerf Mega Magnus Spring Replacement: paso 5, imagen 1 de 3 Nerf Mega Magnus Spring Replacement: paso 5, imagen 2 de 3 Nerf Mega Magnus Spring Replacement: paso 5, imagen 3 de 3
    • Remove the screws from the trigger mechanism and lift it upward
  6. Nerf Mega Magnus Spring Replacement: paso 6, imagen 1 de 2 Nerf Mega Magnus Spring Replacement: paso 6, imagen 2 de 2
    • Locate the small grey piece under the plunger tube and remove the screw.
  7. Nerf Mega Magnus Spring Replacement: paso 7, imagen 1 de 3 Nerf Mega Magnus Spring Replacement: paso 7, imagen 2 de 3 Nerf Mega Magnus Spring Replacement: paso 7, imagen 3 de 3
    • Locate the screws on the return spring. Using a counterclockwise rotation, remove both of the screws.
  8. Nerf Mega Magnus Spring Replacement: paso 8, imagen 1 de 2 Nerf Mega Magnus Spring Replacement: paso 8, imagen 2 de 2
    • Using a small tool, carefully remove the spring from its pegs.
  9. Nerf Mega Magnus Spring Replacement: paso 9, imagen 1 de 3 Nerf Mega Magnus Spring Replacement: paso 9, imagen 2 de 3 Nerf Mega Magnus Spring Replacement: paso 9, imagen 3 de 3
    • Locate the screws behind the dart pusher mechanism. Carefully remove each screw.
  10. Nerf Mega Magnus Spring Replacement: paso 10, imagen 1 de 3 Nerf Mega Magnus Spring Replacement: paso 10, imagen 2 de 3 Nerf Mega Magnus Spring Replacement: paso 10, imagen 3 de 3
    • Pull upwards on the dart pusher and spring to remove them.
  11. Nerf Mega Magnus Spring Replacement: paso 11, imagen 1 de 2 Nerf Mega Magnus Spring Replacement: paso 11, imagen 2 de 2
    • Lift up on the magazine plate in order to remove it.
  12. Nerf Mega Magnus Spring Replacement: paso 12, imagen 1 de 3 Nerf Mega Magnus Spring Replacement: paso 12, imagen 2 de 3 Nerf Mega Magnus Spring Replacement: paso 12, imagen 3 de 3
    • Pull upward on the dart lip and it will lift off.
  13. Nerf Mega Magnus Spring Replacement: paso 13, imagen 1 de 3 Nerf Mega Magnus Spring Replacement: paso 13, imagen 2 de 3 Nerf Mega Magnus Spring Replacement: paso 13, imagen 3 de 3
    • Lift the left side of the plunger tube from its peg and the rest will slide off the spring peg.
  14. Nerf Mega Magnus Spring Replacement: paso 14, imagen 1 de 3 Nerf Mega Magnus Spring Replacement: paso 14, imagen 2 de 3 Nerf Mega Magnus Spring Replacement: paso 14, imagen 3 de 3
    • Slide the spring off its peg. If the spring is damaged, replace it.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 8
Todo El Tiempo: 3,557
