Saltar al contenido principal
Nerf Dart Tag Furyfire Pump Track Replacement
Qué necesitas
  1. Nerf Dart Tag Furyfire Pump Track Replacement, Remove the screws: paso 1, imagen 1 de 1
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Panel: paso 2, imagen 1 de 1
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Black Cylinder: paso 3, imagen 1 de 1
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Spring: paso 4, imagen 1 de 2 Nerf Dart Tag Furyfire Pump Track Replacement, Remove Spring: paso 4, imagen 2 de 2
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
  5. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Pump Handle: paso 5, imagen 1 de 1
    • Remove the two screws circled in blue. They are .95 cm in length.
    • Remove the three screw circled in green. They are .7 cm in length.
  6. Nerf Dart Tag Furyfire Pump Track Replacement, Remove the Pump Handle: paso 6, imagen 1 de 1
    • Once all of the screws have been removed lift the pump handle off and set it aside.
  7. Nerf Dart Tag Furyfire Pump Track Replacement, Remove Attached Spring: paso 7, imagen 1 de 2 Nerf Dart Tag Furyfire Pump Track Replacement, Remove Attached Spring: paso 7, imagen 2 de 2
    • In order to remove the white plastic holder, you must remove the spring that keeps it in place. Using a 00 Phillips screwdriver, carefully remove the screw while holding the spring in place.
  8. Nerf Dart Tag Furyfire Pump Track Replacement, Disengage White Piece: paso 8, imagen 1 de 1
    • Using a plastic opening tool, lift the white piece out of the gun and set it aside.
  9. Nerf Dart Tag Furyfire Pump Track Replacement, Remove the Pump Track: paso 9, imagen 1 de 2 Nerf Dart Tag Furyfire Pump Track Replacement, Remove the Pump Track: paso 9, imagen 2 de 2
    • Using your hand, slide the track out of the gun by pulling it away form the device.
Conclusión
Una persona más ha completado esta guía.
Bradley Penrow
Miembro Desde 09/23/14
37 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 11-2, Blackwell Fall 2014 Miembro de USF Tampa, Team 11-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G2
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 8
Todo El Tiempo: 484
