Saltar al contenido principal
Nerf Dart Tag Furyfire Large Spring Replacement
Qué necesitas
  1. Nerf Dart Tag Furyfire Large Spring Replacement, Remove the screws: paso 1, imagen 1 de 1
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Panel: paso 2, imagen 1 de 1
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Black Cylinder: paso 3, imagen 1 de 1
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Large Spring Replacement, Remove Spring: paso 4, imagen 1 de 2 Nerf Dart Tag Furyfire Large Spring Replacement, Remove Spring: paso 4, imagen 2 de 2
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
Conclusión
Bradley Penrow
Miembro Desde 09/23/14
37 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 11-2, Blackwell Fall 2014 Miembro de USF Tampa, Team 11-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G2
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 1,444
