Saltar al contenido principal
Nerf Dart Tag Furyfire Chamber Replacement
Qué necesitas
  1. Nerf Dart Tag Furyfire Chamber Replacement, Remove the screws: paso 1, imagen 1 de 1
    • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
  2. Nerf Dart Tag Furyfire Chamber Replacement, Remove Panel: paso 2, imagen 1 de 1
    • After the screws have been removed, gently lift the panel from the gun and set it aside.
  3. Nerf Dart Tag Furyfire Chamber Replacement, Remove Black Cylinder: paso 3, imagen 1 de 1
    • Locate the black cylinder connected to the large spring near the top of the device.
    • Once located, push the black cylinder against the spring and lift it out of the device.
  4. Nerf Dart Tag Furyfire Chamber Replacement, Remove Spring: paso 4, imagen 1 de 2 Nerf Dart Tag Furyfire Chamber Replacement, Remove Spring: paso 4, imagen 2 de 2
    • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
    • Ensure that the small spring connected to the stabilizing piece remains connected.
  5. Nerf Dart Tag Furyfire Chamber Replacement, Remove Pump Handle: paso 5, imagen 1 de 1
    • Remove the two screws circled in blue. They are .95 cm in length.
    • Remove the three screw circled in green. They are .7 cm in length.
  6. Nerf Dart Tag Furyfire Chamber Replacement, Remove the Pump Handle: paso 6, imagen 1 de 1
    • Once all of the screws have been removed lift the pump handle off and set it aside.
  7. Nerf Dart Tag Furyfire Chamber Replacement, Remove Attached Spring: paso 7, imagen 1 de 2 Nerf Dart Tag Furyfire Chamber Replacement, Remove Attached Spring: paso 7, imagen 2 de 2
    • In order to remove the white plastic holder, you must remove the spring that keeps it in place. Using a 00 Phillips screwdriver, carefully remove the screw while holding the spring in place.
  8. Nerf Dart Tag Furyfire Chamber Replacement, Disengage White Piece: paso 8, imagen 1 de 1
    • Using a plastic opening tool, lift the white piece out of the gun and set it aside.
  9. Nerf Dart Tag Furyfire Chamber Replacement, Remove the Pump Track: paso 9, imagen 1 de 2 Nerf Dart Tag Furyfire Chamber Replacement, Remove the Pump Track: paso 9, imagen 2 de 2
    • Using your hand, slide the track out of the gun by pulling it away form the device.
  10. Nerf Dart Tag Furyfire Chamber Replacement, Detach Black Piece from Trigger: paso 10, imagen 1 de 1
    • Using a plastic opening tool, detach the black piece from the trigger. You do not need to remove the black piece from the gun.
  11. Nerf Dart Tag Furyfire Chamber Replacement, Remove Trigger: paso 11, imagen 1 de 1
    • Once the black piece has been detached, the trigger can be lifted out of the device.
  12. Nerf Dart Tag Furyfire Chamber Replacement, Remove Black Connector: paso 12, imagen 1 de 1
    • Once the trigger has been removed, simply pull the black connector out of the chamber. Set it aside.
  13. Nerf Dart Tag Furyfire Chamber Replacement, Separate Barrel and Chamber from the Main Body: paso 13, imagen 1 de 2 Nerf Dart Tag Furyfire Chamber Replacement, Separate Barrel and Chamber from the Main Body: paso 13, imagen 2 de 2
    • With your hands gently grasp the barrel and chamber of the gun, and pull it away from the main body.
  14. Nerf Dart Tag Furyfire Chamber Replacement, Separate Barrel and Chamber: paso 14, imagen 1 de 1
    • Using your hands, remove the barrel from the rotating chamber.
Conclusión
Una persona más ha completado esta guía.
Bradley Penrow
Miembro Desde 09/23/14
37 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 11-2, Blackwell Fall 2014 Miembro de USF Tampa, Team 11-2, Blackwell Fall 2014
USFT-BLACKWELL-F14S11G2
4 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 1,115
