Saltar al contenido principal
Neo3Do Front and Back Camera Replacement
Qué necesitas
  1. Neo3Do Front and Back Camera Replacement, Back Panel: paso 1, imagen 1 de 3 Neo3Do Front and Back Camera Replacement, Back Panel: paso 1, imagen 2 de 3 Neo3Do Front and Back Camera Replacement, Back Panel: paso 1, imagen 3 de 3
    • Turn the Neo3DO face down so that the logo is facing toward you.
    • Insert the plastic opening tool between the metal frame and the plastic back panel, as shown.
  2. Neo3Do Front and Back Camera Replacement: paso 2, imagen 1 de 2 Neo3Do Front and Back Camera Replacement: paso 2, imagen 2 de 2
    • Gently pry the back panel upwards.
    • Ensure the tool does not slip into the device and damage the internals.
  3. Neo3Do Front and Back Camera Replacement: paso 3, imagen 1 de 2 Neo3Do Front and Back Camera Replacement: paso 3, imagen 2 de 2
    • Once the back panel has been pried away from the bottom and sides of the Neo3DO, lift the back panel up and away from the tablet.
  4. Neo3Do Front and Back Camera Replacement: paso 4, imagen 1 de 1
    • When replacing the back panel, place the top edge of the back panel against the top edge of the Neo3DO, as shown.
    • The top edge of the device is the edge closest to the camera. The top of the back panel is the side with the hole for the camera.
  5. Neo3Do Front and Back Camera Replacement, Front and Back Camera: paso 5, imagen 1 de 3 Neo3Do Front and Back Camera Replacement, Front and Back Camera: paso 5, imagen 2 de 3 Neo3Do Front and Back Camera Replacement, Front and Back Camera: paso 5, imagen 3 de 3
    • Remove the front and back camera from their sockets.
    • Remove the silver tape from the battery.
  6. Neo3Do Front and Back Camera Replacement: paso 6, imagen 1 de 3 Neo3Do Front and Back Camera Replacement: paso 6, imagen 2 de 3 Neo3Do Front and Back Camera Replacement: paso 6, imagen 3 de 3
    • Remove the ribbon wire from the socket.
    • Gripping the wire belt and pulling upwards may cause damage, be sure to avoid it.
Conclusión
Daniel Evans
Miembro Desde 09/26/16
431 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 14-3, Eyestone Fall 2016 Miembro de USF Tampa, Team 14-3, Eyestone Fall 2016
USFT-EYESTONE-F16S14G3
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 9
Todo El Tiempo: 106
