Introducción
More often than not, necklaces brake. No matter how old or how valuable, the most common breakage occurs when the jump ring slit gets pulled apart and the chain slips out. However, this is an easy fix!
Qué necesitas
Look closely at where the necklace chain came apart. You will see a split ring, otherwise known as a jump ring.
Figure A: The jump ring is located on one end of the necklace.
Now that the jump ring opening is separated, you can reattach the chain. Find the end of the chain that had detached from the necklace.
Figures D and E: While holding the jump ring in one hand and the end of the necklace in your other hand, proceed to loop the chain into the opened jump ring.
To make sure the necklace is correctly reattached, gently pull on the chain. The jump ring should be firmly closed as to prevent the chain from slipping off the jump ring.
5 personas más completaron esta guía.
