Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Necklace Barrel Clasp Repair
Qué necesitas
    1. Necklace Barrel Clasp Repair, Necklace Barrel Clasp Repair: paso 1, imagen 1 de 2 Necklace Barrel Clasp Repair, Necklace Barrel Clasp Repair: paso 1, imagen 2 de 2
      • Locate the broken part of the ring that attaches through the back of the barrel clasp.
      • Bend the portion of the ring with needle nose pliers until the newly compact ring can be pushed through the barrel clasp and fit snug.
      Pregunta a FixBot
      Agregar Comentario
    2. Necklace Barrel Clasp Repair: paso 2, imagen 1 de 1
      • Plug in the electric soldering iron and set the solder temperature to the degrees that suits the melting point of both the soldering wire and the barrel clasp.
      • The soldering iron tip can get extremely hot and will cause severe burns if comes into direct contact with skin. Ensure you keep a safe distance, and wear safety equipment.
      • This method is not recommended for precious metals.
      Pregunta a FixBot
      Agregar Comentario
    3. Necklace Barrel Clasp Repair: paso 3, imagen 1 de 1
      • Molten metal is extremely hot and will cause severe burns. Handle the soldering gun with care and keep your distance from the melting metal.
      • Solder the base of the barrel clasp where the metal ring fits in, intersecting the tips of the soldering gun and soldering wire.
      • Ensure the barrel clasp and ring connection is covered, allowing anywhere from 10 to 30 seconds for the bond to harden and cool.
      Pregunta a FixBot
      Agregar Comentario
    4. Necklace Barrel Clasp Repair: paso 4, imagen 1 de 1
      • Attach the barrel clasp necklace back together and hold each end of the necklace taught to test the solder strength.
      • Do not pull too hard—the amount of strain may cause the solder to break.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Garrett Key
Miembro Desde 07/12/17
110 Reputación
1 Guía escrita
Equipo
Texas Tech, Team S1-G5, Rauch Summer 2017 Miembro de Texas Tech, Team S1-G5, Rauch Summer 2017
TTU-RAUCH-SU17S1G5
Miembros de 3
7 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 62
Todo El Tiempo: 3,737
