Introducción
This guide will show the user how to disassemble the Neato XV-21, locate the motor and disconnect the motor. The user can then follow the guide in reverse to connect and reassemble the Neato XV-21.
Qué necesitas
Flip the Neato on its back so the bottom is exposed
Unscrew the seven screws.
Pinch and pull the white connector to disconnect the battery from the device
Lift and remove the battery from the cavity
Remove the 17 visible screws and the 2 covered/hidden screws near the battery compartments that connect the bottom to the top of the Neato robot.
Una persona más ha completado esta guía.
Un comentario
Mine has a wire jumper that I can't remember where it goes. It appears to be an extension for the Lidar motor wires, but I can't say for sure if that's where it was when I took this apart over a year ago. I can't find anywhere else it might go.
were those common in these? or do know of anyplace else it might go?
Thanks!
