Saltar al contenido principal
Neato XV-21 Fan Replacement
Qué necesitas
  1. Neato XV-21 Fan Replacement, Back Panels of Neato XV-21: paso 1, imagen 1 de 1
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
  2. Neato XV-21 Fan Replacement: paso 2, imagen 1 de 1
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. Neato XV-21 Fan Replacement: paso 3, imagen 1 de 1
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Neato XV-21 Fan Replacement, Battery: paso 4, imagen 1 de 1
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
  5. Neato XV-21 Fan Replacement, Fan: paso 5, imagen 1 de 2 Neato XV-21 Fan Replacement, Fan: paso 5, imagen 2 de 2
    • Pinch the white connectors to disconnect the fan from the robot, as previously done with the batteries
    • Once the wires are disconnected lift the fan from the cavity
  6. Neato XV-21 Fan Replacement: paso 6, imagen 1 de 1
    • Once the fan has been removed you can take a damp cloth and clean the cavity before attaching the new device
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 1,171
