Saltar al contenido principal
Neato XV-21 Battery Replacement/Removal
Qué necesitas
  1. Neato XV-21 Battery Replacement/Removal, Back Panels of Neato XV-21: paso 1, imagen 1 de 1
    • Flip the Neato on its back so the bottom is exposed
    • Unscrew the seven screws.
  2. Neato XV-21 Battery Replacement/Removal: paso 2, imagen 1 de 1
    • Lift the panels to reveal the batteries, brush and fan
    • There should be little to no resistance during this step, do not continue if the pieces do not separate easily
  3. Neato XV-21 Battery Replacement/Removal: paso 3, imagen 1 de 1
    • The Neato's core components are now exposed and ready to be cleaned and/or replaced.
  4. Neato XV-21 Battery Replacement/Removal, Battery: paso 4, imagen 1 de 1
    • Pinch and pull the white connector to disconnect the battery from the device
    • Failure to complete this step could cause electric shock or later complications
    • Lift and remove the battery from the cavity
    • If replacing the battery, make sure to use proper disposal methods.
Conclusión
3 personas más completaron esta guía.
Un comentario
Can someone tell me the specs of screws for the back panels? unfortunately I lost the 8 screws!!!
mflorest - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 1,331
