Saltar al contenido principal
Neato XV Signature Wheel Assembly Replacement
Qué necesitas
  1. Neato XV Signature Wheel Assembly Replacement, Wheel Assembly: paso 1, imagen 1 de 1
    • Place the Neato with the bottom side facing up.
  2. Neato XV Signature Wheel Assembly Replacement: paso 2, imagen 1 de 1
    • Remove the four machine screws securing the main compartment plate using a Phillips #0 screwdriver.
  3. Neato XV Signature Wheel Assembly Replacement: paso 3, imagen 1 de 2 Neato XV Signature Wheel Assembly Replacement: paso 3, imagen 2 de 2
    • Remove the main compartment plate, exposing the wheel axis and fan.
  4. Neato XV Signature Wheel Assembly Replacement: paso 4, imagen 1 de 1
    • Lift up on the wheel axis to remove the axle bar from its clasp.
  5. Neato XV Signature Wheel Assembly Replacement: paso 5, imagen 1 de 2 Neato XV Signature Wheel Assembly Replacement: paso 5, imagen 2 de 2
    • Remove the axle bar from the wheel mount, exposing the suspension spring.
  6. Neato XV Signature Wheel Assembly Replacement: paso 6, imagen 1 de 2 Neato XV Signature Wheel Assembly Replacement: paso 6, imagen 2 de 2
    • Unlatch the suspension spring from the wheel mount, exposing the wheel connector cable.
  7. Neato XV Signature Wheel Assembly Replacement: paso 7, imagen 1 de 1
    • Unplug the wheel connector cable.
    • Repeat steps 4-7 with the other wheel.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 192
