Saltar al contenido principal
Neato Botvac D8000 Top Face Panel Replacement
Qué necesitas
  1. Neato Botvac D8000 Top Face Panel Replacement, Top Face Panel: paso 1, imagen 1 de 1
    • Grab the rear bumper with both hands on either side.
  2. Neato Botvac D8000 Top Face Panel Replacement: paso 2, imagen 1 de 2 Neato Botvac D8000 Top Face Panel Replacement: paso 2, imagen 2 de 2
    • Firmly pull the bumper forward at a steady pace.
    • When pulling the bumper forward avoid being too rough because the bumper might break.
  3. Neato Botvac D8000 Top Face Panel Replacement: paso 3, imagen 1 de 2 Neato Botvac D8000 Top Face Panel Replacement: paso 3, imagen 2 de 2
    • Looking from above, remove the two 11mm screws with a Torx T10 screwdriver.
  4. Neato Botvac D8000 Top Face Panel Replacement: paso 4, imagen 1 de 3 Neato Botvac D8000 Top Face Panel Replacement: paso 4, imagen 2 de 3 Neato Botvac D8000 Top Face Panel Replacement: paso 4, imagen 3 de 3
    • Place the robot on its back and remove the six 11mm screws using a Torx T10 screwdriver.
  5. Neato Botvac D8000 Top Face Panel Replacement: paso 5, imagen 1 de 3 Neato Botvac D8000 Top Face Panel Replacement: paso 5, imagen 2 de 3 Neato Botvac D8000 Top Face Panel Replacement: paso 5, imagen 3 de 3
    • Push the clips, located in the back side, inward.
    • Gently lift up the top cover until you can see the wires. Then gently un-clip all the wires.
    • When you lift the top cover be careful because the wires are thin and fragile.
  6. Neato Botvac D8000 Top Face Panel Replacement: paso 6, imagen 1 de 1
    • Once you have carefully removed the wire clip; you can fully remove the top cover.
Conclusión
2 personas más completaron esta guía.
Ruth Lopez
Miembro Desde 03/22/18
280 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 9
Todo El Tiempo: 920
