Saltar al contenido principal
Neato Botvac D8000 Battery Replacement
Qué necesitas
  1. Neato Botvac D8000 Battery Replacement, Battery: paso 1, imagen 1 de 2 Neato Botvac D8000 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Turn the robot upside down to locate the battery cover.
  2. Neato Botvac D8000 Battery Replacement: paso 2, imagen 1 de 3 Neato Botvac D8000 Battery Replacement: paso 2, imagen 2 de 3 Neato Botvac D8000 Battery Replacement: paso 2, imagen 3 de 3
    • Use a Phillips #1 screwdriver to unscrew both of the 20mm screws.
    • Gently lift the battery cover.
    • Remove the battery cover to reveal the battery.
  3. Neato Botvac D8000 Battery Replacement: paso 3, imagen 1 de 3 Neato Botvac D8000 Battery Replacement: paso 3, imagen 2 de 3 Neato Botvac D8000 Battery Replacement: paso 3, imagen 3 de 3
    • Use a flathead screwdriver to push down on the latch of the battery clip.
    • Simultaneously, pull on the battery while pushing down on the latch to detach the battery from the clip.
    • Do not pull on the wires that are connected to the battery.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 831
