Saltar al contenido principal
Neato Botvac D75 Brushes Replacement
Qué necesitas
  1. Neato Botvac D75 Brushes Replacement, Brushes: paso 1, imagen 1 de 3 Neato Botvac D75 Brushes Replacement, Brushes: paso 1, imagen 2 de 3 Neato Botvac D75 Brushes Replacement, Brushes: paso 1, imagen 3 de 3
    • To remove the rotary brush simply grasp it firmly and pull it off.
  2. Neato Botvac D75 Brushes Replacement: paso 2, imagen 1 de 3 Neato Botvac D75 Brushes Replacement: paso 2, imagen 2 de 3 Neato Botvac D75 Brushes Replacement: paso 2, imagen 3 de 3
    • Once you have everything out get the plastic opening tool and pry open the large black plastic piece.
    • With a little force it should come out.
    • The boxes show you were the clips are that hold this piece
  3. Neato Botvac D75 Brushes Replacement: paso 3, imagen 1 de 1
    • Once the black piece has been taken out, the brush just comes out easily.
Conclusión
Juan Cornejo
Miembro Desde 02/15/17
597 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S6-G5, Lacy Spring 2017 Miembro de USF Tampa, Team S6-G5, Lacy Spring 2017
USFT-LACY-S17S6G5
4 Miembros
10 Guías creadas
Un comentario
I have removed and cleaned the brush but it still won't run due to the error message to clean the brush. The machine has only run 5 or 6 times so brand new machine.
keytkey - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 11
Todo El Tiempo: 915
