Saltar al contenido principal
Neato Botvac D75 Battery Replacement
Qué necesitas
  1. Neato Botvac D75 Battery Replacement, Battery: paso 1, imagen 1 de 3 Neato Botvac D75 Battery Replacement, Battery: paso 1, imagen 2 de 3 Neato Botvac D75 Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Use Phillips #1 screwdriver to unscrew the two bottom cover screws
    • Be careful, the screws are self-retained on the cover itself and does not come off the battery cover.
  2. Neato Botvac D75 Battery Replacement: paso 2, imagen 1 de 3 Neato Botvac D75 Battery Replacement: paso 2, imagen 2 de 3 Neato Botvac D75 Battery Replacement: paso 2, imagen 3 de 3
    • Lift battery cover out.
  3. Neato Botvac D75 Battery Replacement: paso 3, imagen 1 de 3 Neato Botvac D75 Battery Replacement: paso 3, imagen 2 de 3 Neato Botvac D75 Battery Replacement: paso 3, imagen 3 de 3
    • Be careful when taking out the battery. Do not pull on the wires or battery trying to get the connector out.
    • The cord has prongs on it that are a little difficult to get out. Use a flathead screwdriver to press the release tab on the connector to remove it.
Conclusión
Una persona más ha completado esta guía.
Juan Cornejo
Miembro Desde 02/15/17
597 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S6-G5, Lacy Spring 2017 Miembro de USF Tampa, Team S6-G5, Lacy Spring 2017
USFT-LACY-S17S6G5
4 Miembros
10 Guías creadas
Un comentario
Thanks for the tuto.
an additionnal info when having a battery issue, is to the reset to new battery. enter the menu, then help, and chose new battery.
it seems the neato system is set for planned obsolescence… unfortunatly for customers….
so I did it because battery stayed empty while plugged and switch found ok . And new my botvac is ok, like new!!
Nom - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 34
Todo El Tiempo: 2,164
