Introducción
This guide will aid you in replacing the wall sensor on your Botvac.
Qué necesitas
Flip the Botvac over so that the underside is facing up and the flat front is facing toward you.
Remove the four screws lining the front roller using a TR10 Torx screwdriver.
Remove the black panel behind and in front of the roller.
Gently lift the roller by the right side to remove it.
Casi Terminas!
Conclusión
