Saltar al contenido principal
Neato BOTVAC CONNECTED Side Wheel Replacement
Qué necesitas
  1. Neato BOTVAC CONNECTED Side Wheel Replacement, Battery: paso 1, imagen 1 de 1
    • Place the top of the Neato Botvac Connected against a flat surface.
  2. Neato BOTVAC CONNECTED Side Wheel Replacement: paso 2, imagen 1 de 2 Neato BOTVAC CONNECTED Side Wheel Replacement: paso 2, imagen 2 de 2
    • Remove the two 5.5 mm screws with a Phillips #2 screwdriver.
  3. Neato BOTVAC CONNECTED Side Wheel Replacement: paso 3, imagen 1 de 2 Neato BOTVAC CONNECTED Side Wheel Replacement: paso 3, imagen 2 de 2
    • Using the spudger, remove the panel covering the battery.
  4. Neato BOTVAC CONNECTED Side Wheel Replacement: paso 4, imagen 1 de 3 Neato BOTVAC CONNECTED Side Wheel Replacement: paso 4, imagen 2 de 3 Neato BOTVAC CONNECTED Side Wheel Replacement: paso 4, imagen 3 de 3
    • Gently remove the connecting wires attached to the battery.
    • The wires are attached to the vacuum through a clip.
  5. Neato BOTVAC CONNECTED Side Wheel Replacement: paso 5, imagen 1 de 1
    • Using the spudger, gently remove the battery from the device.
  6. Neato BOTVAC CONNECTED Side Wheel Replacement, Front Roller Brush: paso 6, imagen 1 de 2 Neato BOTVAC CONNECTED Side Wheel Replacement, Front Roller Brush: paso 6, imagen 2 de 2
    • Remove the following screws with a Torx screwdriver:
    • Four 2.3 mm screws.
  7. Neato BOTVAC CONNECTED Side Wheel Replacement: paso 7, imagen 1 de 1
    • Gently remove the thin panel held by the four screws with a spudger.
  8. Neato BOTVAC CONNECTED Side Wheel Replacement: paso 8, imagen 1 de 1
    • Gently remove the two small wheels, and the axles attached to them.
  9. Neato BOTVAC CONNECTED Side Wheel Replacement: paso 9, imagen 1 de 1
    • Gently remove the panel that is on top of the front roller with the spudger.
  10. Neato BOTVAC CONNECTED Side Wheel Replacement: paso 10, imagen 1 de 1
    • Gently remove the front brush.
  11. Neato BOTVAC CONNECTED Side Wheel Replacement, Side Brush: paso 11, imagen 1 de 2 Neato BOTVAC CONNECTED Side Wheel Replacement, Side Brush: paso 11, imagen 2 de 2
    • Gently twist the side brush back and forth.
  12. Neato BOTVAC CONNECTED Side Wheel Replacement: paso 12, imagen 1 de 3 Neato BOTVAC CONNECTED Side Wheel Replacement: paso 12, imagen 2 de 3 Neato BOTVAC CONNECTED Side Wheel Replacement: paso 12, imagen 3 de 3
    • Spin the side brush counter counterclockwise.
  13. Neato BOTVAC CONNECTED Side Wheel Replacement: paso 13, imagen 1 de 1
    • Use the spudger to gently pry up and remove the side brush.
  14. Neato BOTVAC CONNECTED Side Wheel Replacement, Filter: paso 14, imagen 1 de 1
    • Flip the cleaner around and locate the front panel.
  15. Neato BOTVAC CONNECTED Side Wheel Replacement: paso 15, imagen 1 de 1
    • Gently remove the front panel by opening it with a spudger.
  16. Neato BOTVAC CONNECTED Side Wheel Replacement: paso 16, imagen 1 de 2 Neato BOTVAC CONNECTED Side Wheel Replacement: paso 16, imagen 2 de 2
    • Use the spudger to gently remove the paper filter.
  17. Neato BOTVAC CONNECTED Side Wheel Replacement, Side Wheel: paso 17, imagen 1 de 1
    • Remove the following screws with a TR10 Torx screwdriver:
    • Six 2.3 mm screws.
  18. Neato BOTVAC CONNECTED Side Wheel Replacement: paso 18, imagen 1 de 2 Neato BOTVAC CONNECTED Side Wheel Replacement: paso 18, imagen 2 de 2
    • Remove the front bumper by pulling it horizontally on each side.
  19. Neato BOTVAC CONNECTED Side Wheel Replacement: paso 19, imagen 1 de 1
    • Remove the screw that is directly attached to the wheel on the side using a Phillips #2 screwdriver.
  20. Neato BOTVAC CONNECTED Side Wheel Replacement: paso 20, imagen 1 de 1
    • Remove the two 2.3 mm screws on the front of the vacuum with a TR10 Torx screwdriver.
  21. Neato BOTVAC CONNECTED Side Wheel Replacement: paso 21, imagen 1 de 1
    • Remove the layer below the front bumper by pressing firmly on the two levers located nearby.
  22. Neato BOTVAC CONNECTED Side Wheel Replacement: paso 22, imagen 1 de 3 Neato BOTVAC CONNECTED Side Wheel Replacement: paso 22, imagen 2 de 3 Neato BOTVAC CONNECTED Side Wheel Replacement: paso 22, imagen 3 de 3
    • Gently take out the top panel, and take out the connecting wires.
  23. Neato BOTVAC CONNECTED Side Wheel Replacement: paso 23, imagen 1 de 1
    • Two 2.3 mm screws.
  24. Neato BOTVAC CONNECTED Side Wheel Replacement: paso 24, imagen 1 de 1
    • Flip around the vacuum and remove the wheel with the spudger.
Conclusión
Una persona más ha completado esta guía.
Justin Silva
Miembro Desde 03/20/23
645 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 231
