Saltar al contenido principal
Neato BOTVAC CONNECTED Battery Replacement
Qué necesitas
  1. Neato BOTVAC CONNECTED Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Place the top of the Neato Botvac Connected against a flat surface.
  2. Neato BOTVAC CONNECTED Battery Replacement: paso 2, imagen 1 de 2 Neato BOTVAC CONNECTED Battery Replacement: paso 2, imagen 2 de 2
    • Remove the two 5.5 mm screws with a Phillips #2 screwdriver.
  3. Neato BOTVAC CONNECTED Battery Replacement: paso 3, imagen 1 de 2 Neato BOTVAC CONNECTED Battery Replacement: paso 3, imagen 2 de 2
    • Using the spudger, remove the panel covering the battery.
  4. Neato BOTVAC CONNECTED Battery Replacement: paso 4, imagen 1 de 3 Neato BOTVAC CONNECTED Battery Replacement: paso 4, imagen 2 de 3 Neato BOTVAC CONNECTED Battery Replacement: paso 4, imagen 3 de 3
    • Gently remove the connecting wires attached to the battery.
    • The wires are attached to the vacuum through a clip.
  5. Neato BOTVAC CONNECTED Battery Replacement: paso 5, imagen 1 de 1
    • Using the spudger, gently remove the battery from the device.
Conclusión
Justin Silva
Miembro Desde 03/20/23
645 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 36
Todo El Tiempo: 364
