Introducción
The power button is located next to the volume buttons on the top side of the tablet when looking at it in front view. Make sure power button is not stuck within the frame of the tablet or broken. If so, carefully follow the fixing guide to replace or push out button if stuck. Once open, make sure that power button is making contact with inner power button through black ribbon sitting between both buttons.
Qué necesitas
Locate the power button assembly on the side with all the circuit boards.
