Saltar al contenido principal
Nabi Big Tab HD24 Charging Port Replacement
Qué necesitas
  1. Nabi Big Tab HD24  Charging  Port Replacement, Back Assembly: paso 1, imagen 1 de 1
    • Ensure that the tablet is facing you with the screen on the table.
    • Locate the four red rubber stops at the corners.
  2. Nabi Big Tab HD24  Charging  Port Replacement: paso 2, imagen 1 de 1
    • Use your fingers to carefully peel them off the device to reveal the screws underneath.
  3. Nabi Big Tab HD24  Charging  Port Replacement: paso 3, imagen 1 de 1
    • Use a Phillips #1 screwdriver to remove the 9.5 mm screw in each of the four corners.
  4. Nabi Big Tab HD24  Charging  Port Replacement: paso 4, imagen 1 de 1
    • Flip the tablet over such that the screen is facing upwards.
    • Locate the the 4 small openings on the sides of the tablet.
    • There should be 2 on the bottom of the tablet, 1 on each side of the tablet viewing it from the front as if you were using it.
    • Do not confuse the openings with the charging port or the USB ports. The openings will be labelled with an icon of a small fan, the Nabi logo.
  5. Nabi Big Tab HD24  Charging  Port Replacement: paso 5, imagen 1 de 1
    • Insert a metal spudger into one of the openings and carefully pop the device open by applying a steady downward force.
    • Repeat for the other three openings.
  6. Nabi Big Tab HD24  Charging  Port Replacement: paso 6, imagen 1 de 2 Nabi Big Tab HD24  Charging  Port Replacement: paso 6, imagen 2 de 2
    • Flip the device over so that the back assembly is facing you.
    • Use a plastic opening tool to carefully pry open the device from its hinges.
    • Take care when opening the device as there are cables running internally that are connected to both the front and the back assemblies.
  7. Nabi Big Tab HD24  Charging  Port Replacement: paso 7, imagen 1 de 2 Nabi Big Tab HD24  Charging  Port Replacement: paso 7, imagen 2 de 2
    • Locate the white port that connects the back panel to the circuit board on the back of the display.
    • Carefully pull the plastic connector straight out.
  8. Nabi Big Tab HD24  Charging  Port Replacement: paso 8, imagen 1 de 1
    • Be careful of the aluminum foil tape, as it can easily rip.
    • Carefully lift up the aluminum foil tape with your fingers so that the ribbon connector reveals itself.
    • Do not try to pull the ribbon cables off the screen as there is a plastic piece surrounding the ribbon cables glued onto the metal display.
  9. Nabi Big Tab HD24  Charging  Port Replacement: paso 9, imagen 1 de 1
    • Firmly press the two switches located on the sides of the connector and disconnect the connector from its connections.
    • Leave the connector disconnected but still intact with the metal display.
  10. Nabi Big Tab HD24  Charging  Port Replacement: paso 10, imagen 1 de 1
    • Use a plastic opening tool and carefully push it underneath the grey plastic case surrounding the ribbon cable.
    • Apply a downward force to carefully peel the grey plastic off of the metal display.
  11. Nabi Big Tab HD24  Charging  Port Replacement: paso 11, imagen 1 de 1
    • Locate the two cables running on both sides of the device found at the bottom side of the screen.
  12. Nabi Big Tab HD24  Charging  Port Replacement: paso 12, imagen 1 de 2 Nabi Big Tab HD24  Charging  Port Replacement: paso 12, imagen 2 de 2
    • Carefully grab both sides of the white plastic piece with your fingers and gently pull directly upward.
    • Do not pull from the red and black cable as it is not very sturdy and may come undone from the connector.
  13. Nabi Big Tab HD24  Charging  Port Replacement, Battery Charging Port: paso 13, imagen 1 de 2 Nabi Big Tab HD24  Charging  Port Replacement, Battery Charging Port: paso 13, imagen 2 de 2
    • Locate the battery charging port labeled "DC" on the side of the tablet .
  14. Nabi Big Tab HD24  Charging  Port Replacement: paso 14, imagen 1 de 2 Nabi Big Tab HD24  Charging  Port Replacement: paso 14, imagen 2 de 2
    • Use a Philips #1 screw driver to unscrew the two silver 4.5 mm screws located on top of the circuit board.
  15. Nabi Big Tab HD24  Charging  Port Replacement: paso 15, imagen 1 de 1
    • Disconnect the white port with black and red cables from the circuit board with your hands.
    • It may take a few tries to remove the cable, since it is connected very tightly. Wiggling it some may help.
    • Replace your circuit board with the new one.
Conclusión
Una persona más ha completado esta guía.
Karen Lopez
Miembro Desde 10/06/16
125 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 4-1, Livingston Fall 2016 Miembro de Cal Poly, Team 4-1, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G1
4 Miembros
14 Guías creadas
2 comentarios
Hi! Awesome! One question. Where do I get a new charging circuit board? Thanks!
Gordon Unitas - Contestar
Hi, have Nabi tablet, did you know where can I get the charging circuit board. T Q
David Marzll - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 15
Todo El Tiempo: 2,922
