Saltar al contenido principal
Nabi 2S Camera Replacement
Qué necesitas
  1. Nabi 2S Camera Replacement, Nabi 2S Disassembly: paso 1, imagen 1 de 1
    • Remove the red rubber case from the device.
  2. Nabi 2S Camera Replacement: paso 2, imagen 1 de 2 Nabi 2S Camera Replacement: paso 2, imagen 2 de 2
    • Make sure the screen is facing away from you and the back cover is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the 3mm screws counter-clockwise in each corner of the plastic back cover. It will be a total of four screws. The smaller case on the back cover is attached to the main cover so it will not need to be removed.
  3. Nabi 2S Camera Replacement: paso 3, imagen 1 de 1
    • Using the plastic opening tool, remove the case.
    • Removing the case will take a bit of effort and force. We recommend using two hands and if possible another person to help. It will require some gusto.
    • It is helpful to pry at the corners first to loosen the case.
  4. Nabi 2S Camera Replacement: paso 4, imagen 1 de 1
    • After the back case is loosened, remove it from the device to change or access the battery.
  5. Nabi 2S Camera Replacement, Camera: paso 5, imagen 1 de 2 Nabi 2S Camera Replacement, Camera: paso 5, imagen 2 de 2
    • Unscrew the circuit board from the motherboard by using a Phillips #0 screwdriver to unscrew the ten 4mm screws in a counter-clockwise rotation.
  6. Nabi 2S Camera Replacement: paso 6, imagen 1 de 3 Nabi 2S Camera Replacement: paso 6, imagen 2 de 3 Nabi 2S Camera Replacement: paso 6, imagen 3 de 3
    • The camera is attached to the circuit board and then tucked underneath. Gently grip the part attached to the circuit board and pull it up and away from the circuit.
    • Gently slide the camera out from underneath the circuit board.
    • The camera is stuck to the device with adhesive tape so do not rapidly remove it.
Conclusión
2 personas más completaron esta guía.
Molly Scott
Miembro Desde 03/07/16
275 Reputación
1 Guía escrita
Equipo
Marist, Team 1-4, Laflen Spring 2016 Miembro de Marist, Team 1-4, Laflen Spring 2016
MARS-LAFLEN-S16S1G4
2 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 161
