Saltar al contenido principal
Nabi 2 Internal Speakers Replacement
Qué necesitas
  1. Nabi 2 Internal Speakers Replacement, Nabi 2 Back Cover Removal: paso 1, imagen 1 de 3 Nabi 2 Internal Speakers Replacement, Nabi 2 Back Cover Removal: paso 1, imagen 2 de 3 Nabi 2 Internal Speakers Replacement, Nabi 2 Back Cover Removal: paso 1, imagen 3 de 3
    • Remove the rubber bumper from the tablet.
  2. Nabi 2 Internal Speakers Replacement: paso 2, imagen 1 de 2 Nabi 2 Internal Speakers Replacement: paso 2, imagen 2 de 2
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
  3. Nabi 2 Internal Speakers Replacement: paso 3, imagen 1 de 3 Nabi 2 Internal Speakers Replacement: paso 3, imagen 2 de 3 Nabi 2 Internal Speakers Replacement: paso 3, imagen 3 de 3
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
  4. Nabi 2 Internal Speakers Replacement, Internal Speakers: paso 4, imagen 1 de 1
    • Using the soldering iron, detach the speaker's wires from the circuit board.
  5. Nabi 2 Internal Speakers Replacement: paso 5, imagen 1 de 3 Nabi 2 Internal Speakers Replacement: paso 5, imagen 2 de 3 Nabi 2 Internal Speakers Replacement: paso 5, imagen 3 de 3
    • Using a Phillips PH 000 screwdriver, unscrew the two 3 mm Phillips #000 screws on each side of the speakers that hold the speakers in place.
  6. Nabi 2 Internal Speakers Replacement: paso 6, imagen 1 de 1
    • Once the screws have been removed, remove the speakers from the device.
Conclusión
Michelle
Miembro Desde 02/09/16
851 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 4-3, Lacy Spring 2016 Miembro de USF Tampa, Team 4-3, Lacy Spring 2016
USFT-LACY-S16S4G3
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 747
