Saltar al contenido principal
Nabi 2 Battery Replacement
Qué necesitas
  1. Nabi 2 Battery Replacement, Nabi 2 Back Cover Removal: paso 1, imagen 1 de 3 Nabi 2 Battery Replacement, Nabi 2 Back Cover Removal: paso 1, imagen 2 de 3 Nabi 2 Battery Replacement, Nabi 2 Back Cover Removal: paso 1, imagen 3 de 3
    • Remove the rubber bumper from the tablet.
  2. Nabi 2 Battery Replacement: paso 2, imagen 1 de 2 Nabi 2 Battery Replacement: paso 2, imagen 2 de 2
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
  3. Nabi 2 Battery Replacement: paso 3, imagen 1 de 3 Nabi 2 Battery Replacement: paso 3, imagen 2 de 3 Nabi 2 Battery Replacement: paso 3, imagen 3 de 3
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
  4. Nabi 2 Battery Replacement, Battery: paso 4, imagen 1 de 3 Nabi 2 Battery Replacement, Battery: paso 4, imagen 2 de 3 Nabi 2 Battery Replacement, Battery: paso 4, imagen 3 de 3
    • Use the spudger to pop the battery out of place and set it aside.
  5. Nabi 2 Battery Replacement: paso 5, imagen 1 de 3 Nabi 2 Battery Replacement: paso 5, imagen 2 de 3 Nabi 2 Battery Replacement: paso 5, imagen 3 de 3
    • Desolder the battery connection and remove the battery completely
    • Note the color order for future replacemement
Conclusión
4 personas más completaron esta guía.
Michelle
Miembro Desde 02/09/16
851 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 4-3, Lacy Spring 2016 Miembro de USF Tampa, Team 4-3, Lacy Spring 2016
USFT-LACY-S16S4G3
4 Miembros
14 Guías creadas
3 comentarios
Was hoping you could provide the replacement part number for this battery.
ellenanders5 - Contestar
It shows on the picture: 1ICP6/68/112
Zoltan -
Hi,
where i can buy this replacement battery?
Thanks
Antanas Stankus - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 34
Todo El Tiempo: 9,577
