Saltar al contenido principal
Nabi 2 Screen Replacement
Qué necesitas
  1. Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: paso 1, imagen 1 de 3 Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: paso 1, imagen 2 de 3 Nabi 2  Screen Replacement, Nabi 2 Back Cover Removal: paso 1, imagen 3 de 3
    • Remove the rubber bumper from the tablet.
  2. Nabi 2  Screen Replacement: paso 2, imagen 1 de 2 Nabi 2  Screen Replacement: paso 2, imagen 2 de 2
    • With a PH00 screwdriver, remove the four outermost screws from the back of the tablet.
  3. Nabi 2  Screen Replacement: paso 3, imagen 1 de 3 Nabi 2  Screen Replacement: paso 3, imagen 2 de 3 Nabi 2  Screen Replacement: paso 3, imagen 3 de 3
    • Carefully, insert a plastic opening tool into the seam of the device and begin gently prying the two plastic pieces apart.
    • Work the tool all the way around the device. Small plastic clips should release. If they do not, gently apply outwards pressure until the clips give.
    • Do not force the clips open, as they are fairly easy to break
  4. Nabi 2  Screen Replacement, Screen: paso 4, imagen 1 de 3 Nabi 2  Screen Replacement, Screen: paso 4, imagen 2 de 3 Nabi 2  Screen Replacement, Screen: paso 4, imagen 3 de 3
    • Lay the tablet down flat and remove the yellow tape from the ZIF connector on each side
  5. Nabi 2  Screen Replacement: paso 5, imagen 1 de 3 Nabi 2  Screen Replacement: paso 5, imagen 2 de 3 Nabi 2  Screen Replacement: paso 5, imagen 3 de 3
    • Using a spudger, slide the brown tab forward on each side of the connector
    • Slide until the connector is completely loose, then separate the screen from the bottom half of the tablet
    • If the screen is not working correctly, you will need to replace the entire display assembly
Conclusión
6 personas más completaron esta guía.
Michelle
Miembro Desde 02/09/16
851 Reputación
4 Guías creadas
Equipo
USF Tampa, Team 4-3, Lacy Spring 2016 Miembro de USF Tampa, Team 4-3, Lacy Spring 2016
USFT-LACY-S16S4G3
4 Miembros
14 Guías creadas
3 comentarios
Simple steps but very practical
myjamro - Contestar
Is the LCD glued to the front glass/digitizer?
Brent Huff - Contestar
It Worked Thank U So Much!!!
Sharon Thrash - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 25
Todo El Tiempo: 7,887
