Saltar al contenido principal
NVIDIA P2575 Battery Replacement and Breakdown
Qué necesitas
  1. NVIDIA P2575 Battery Replacement and Breakdown, Get Item and tools in area for dismantle: paso 1, imagen 1 de 3 NVIDIA P2575 Battery Replacement and Breakdown, Get Item and tools in area for dismantle: paso 1, imagen 2 de 3 NVIDIA P2575 Battery Replacement and Breakdown, Get Item and tools in area for dismantle: paso 1, imagen 3 de 3
    • Suggested Items Listed
  2. NVIDIA P2575 Battery Replacement and Breakdown, Removing the Top Cover: paso 2, imagen 1 de 2 NVIDIA P2575 Battery Replacement and Breakdown, Removing the Top Cover: paso 2, imagen 2 de 2
    • From here you will want to use the Jimmy or similar item to get under the bottom corner to get past the inner clips. From here you can carefully get both sides of the bottom top cover and lift it off. The remainder of the cover should come off fairly easily. If not use the jimmy to unclip the others.
  3. NVIDIA P2575 Battery Replacement and Breakdown, Removing buttons and Exposing the circuit: paso 3, imagen 1 de 2 NVIDIA P2575 Battery Replacement and Breakdown, Removing buttons and Exposing the circuit: paso 3, imagen 2 de 2
    • The Buttons are easily removed. The Volume Touch pad is also seen here; it is attached by glue.
  4. NVIDIA P2575 Battery Replacement and Breakdown, Removing the first Circuit Board: paso 4, imagen 1 de 3 NVIDIA P2575 Battery Replacement and Breakdown, Removing the first Circuit Board: paso 4, imagen 2 de 3 NVIDIA P2575 Battery Replacement and Breakdown, Removing the first Circuit Board: paso 4, imagen 3 de 3
    • Use the Jimmy to prop the circuit board from the glue attached to the casing. Becareful of the ribbon attached. The circuit board will come out away from the ribbon if you remove it from the glue.
  5. NVIDIA P2575 Battery Replacement and Breakdown, Removing the Ribbon Cable from Circuit: paso 5, imagen 1 de 2 NVIDIA P2575 Battery Replacement and Breakdown, Removing the Ribbon Cable from Circuit: paso 5, imagen 2 de 2
    • Once you have the Circuit out of the glue you will see the shown Ribbon attachment clip moved up to be removed. Second picture the board is removed.
  6. NVIDIA P2575 Battery Replacement and Breakdown, Removing the Ribbon Sensor and Battery Compartment: paso 6, imagen 1 de 3 NVIDIA P2575 Battery Replacement and Breakdown, Removing the Ribbon Sensor and Battery Compartment: paso 6, imagen 2 de 3 NVIDIA P2575 Battery Replacement and Breakdown, Removing the Ribbon Sensor and Battery Compartment: paso 6, imagen 3 de 3
    • The Sensor Ribbon is carefully peeled away from the glue. There are two options available to get the battery compartment out. You can either use the Tweezers and push near the ribbon cable or you can use the tweezers to push from the other end inside and under the Sensor place as seen in the picture.
  7. NVIDIA P2575 Battery Replacement and Breakdown, Removing the Battery from the housing: paso 7, imagen 1 de 3 NVIDIA P2575 Battery Replacement and Breakdown, Removing the Battery from the housing: paso 7, imagen 2 de 3 NVIDIA P2575 Battery Replacement and Breakdown, Removing the Battery from the housing: paso 7, imagen 3 de 3
    • From here you can remove the Single Phillips Screw using the Phillips 00 Driver Bit. This will let you pry the circuit and battery from the Glue . You can lift the Battery from the Circuit board as it is made to lift upward and away from the board.
  8. NVIDIA P2575 Battery Replacement and Breakdown, Battery and Overall Component Picture: paso 8, imagen 1 de 3 NVIDIA P2575 Battery Replacement and Breakdown, Battery and Overall Component Picture: paso 8, imagen 2 de 3 NVIDIA P2575 Battery Replacement and Breakdown, Battery and Overall Component Picture: paso 8, imagen 3 de 3
    • Insert wisdom here.
Linea de Meta
5 personas más completaron esta guía.
Kevin Jones
Miembro Desde 11/27/12
1,241 Reputación
2 Guías creadas
9 comentarios
I have one slight problem. I opened my remote, now i cant put it back together. The clamp near the charging port just wont get back into place. Nothing is broken. i checked, all clamps are there, but this one just wont slide back in to let me close back the remote. Any tip ?
Remus C - Contestar
YouTube Comment
YouTube Comment
I would double check the female Clamp end on the bottom part. You my have broken the receiving end of the clamp.
YouTube Comment
Thank you for the reply. Sadly both of clamps were ok. I managed to fix by bending the male clamp in the outside position. Also, the female clamp was made of aluminum, so breaking it was impossible. I finally closed it somehow, but it still has a little wiggle on the sides. Well, thats about all that can be done.
Kevin Jones -
Has anyone else experienced that the microphone stops working? I’m thinking maybe it could be fixed by opening it up and.. ?
Thomas Novin - Contestar
Where i can buy the battery?
Samir Selmanovic - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 20
Ultimos 30 días: 98
Todo El Tiempo: 9,092
