Saltar al contenido principal
NP-R540-JA09US Keyboard Replacement
Qué necesitas
  1. NP-R540-JA09US Keyboard Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off laptop before starting.
    • Remove power cable before starting.
    • Flip the laptop over so that the bottom of the laptop is facing upwards.
  2. NP-R540-JA09US Keyboard Replacement: paso 2, imagen 1 de 1
    • Pull the two latches outward.
  3. NP-R540-JA09US Keyboard Replacement: paso 3, imagen 1 de 2 NP-R540-JA09US Keyboard Replacement: paso 3, imagen 2 de 2
    • Slide the battery out of the laptop.
  4. NP-R540-JA09US Keyboard Replacement, Optical Drive: paso 4, imagen 1 de 1
    • Remove securing screw with the PH0 head.
  5. NP-R540-JA09US Keyboard Replacement: paso 5, imagen 1 de 1
    • Slide the optical drive out and remove it from the device.
  6. NP-R540-JA09US Keyboard Replacement, Keyboard: paso 6, imagen 1 de 1
    • Remove the two Phillips #0 screws labeled KBD.
    • There are 5 clips along the top of the keyboard. Insert a thin opener tool (iSessamo tool or similar) between each clip and the keyboard tray to release it.
    • Make sure to pry the metal keyboard base and not the keycaps.
  7. NP-R540-JA09US Keyboard Replacement: paso 8, imagen 1 de 1
    • Do not bend your keyboard as shown in this picture.
    • Lift the keyboard up to release catches on the sides, then slide the keyboard towards the screen to slide tabs out of the slots at the bottom.
  8. NP-R540-JA09US Keyboard Replacement: paso 9, imagen 1 de 2 NP-R540-JA09US Keyboard Replacement: paso 9, imagen 2 de 2
    • Disconnect the keyboard cable from the motherboard.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 851
