Saltar al contenido principal
NETGEAR WGT624 v3 Antenna Replacement
Qué necesitas
  1. NETGEAR WGT624 v3 Antenna Replacement, Lower Case: paso 1, imagen 1 de 1
    • Turn the device so that the bottom is facing up.
  2. NETGEAR WGT624 v3 Antenna Replacement: paso 2, imagen 1 de 3 NETGEAR WGT624 v3 Antenna Replacement: paso 2, imagen 2 de 3 NETGEAR WGT624 v3 Antenna Replacement: paso 2, imagen 3 de 3
    • Use the plastic opening tool to carefully lift the rubber stops in each corner.
    • Do not completely remove the rubber stops, because they are difficult to replace.
  3. NETGEAR WGT624 v3 Antenna Replacement: paso 3, imagen 1 de 2 NETGEAR WGT624 v3 Antenna Replacement: paso 3, imagen 2 de 2
    • Unscrew the 4 11.8 mm T-8 Torx screws from each corner of the device.
  4. NETGEAR WGT624 v3 Antenna Replacement: paso 4, imagen 1 de 2 NETGEAR WGT624 v3 Antenna Replacement: paso 4, imagen 2 de 2
    • Lift the lower case straight up from the rest of the router.
  5. NETGEAR WGT624 v3 Antenna Replacement, Motherboard: paso 5, imagen 1 de 2 NETGEAR WGT624 v3 Antenna Replacement, Motherboard: paso 5, imagen 2 de 2
    • Remove the clear plastic casing by lifting it straight up from the router.
  6. NETGEAR WGT624 v3 Antenna Replacement: paso 6, imagen 1 de 2 NETGEAR WGT624 v3 Antenna Replacement: paso 6, imagen 2 de 2
    • Separate the motherboard from the top shell by lifting it straight up from the router.
  7. NETGEAR WGT624 v3 Antenna Replacement, Antenna: paso 7, imagen 1 de 1
    • Turn the motherboard, so that the top is facing upwards.
    • Place the motherboard on a clean flat surface.
  8. NETGEAR WGT624 v3 Antenna Replacement: paso 8, imagen 1 de 2 NETGEAR WGT624 v3 Antenna Replacement: paso 8, imagen 2 de 2
    • Remove the yellow tape that holds the wire.
    • Make sure that you set the tape aside on a clean surface, so that it can be reused.
  9. NETGEAR WGT624 v3 Antenna Replacement: paso 9, imagen 1 de 3 NETGEAR WGT624 v3 Antenna Replacement: paso 9, imagen 2 de 3 NETGEAR WGT624 v3 Antenna Replacement: paso 9, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to gently pull the metal bracket that connects the antenna to the motherboard.
    • The wire should now be completely separate from the motherboard.
  10. NETGEAR WGT624 v3 Antenna Replacement: paso 10, imagen 1 de 1
    • Extend the antenna away from the device, so that it becomes straight.
  11. NETGEAR WGT624 v3 Antenna Replacement: paso 11, imagen 1 de 3 NETGEAR WGT624 v3 Antenna Replacement: paso 11, imagen 2 de 3 NETGEAR WGT624 v3 Antenna Replacement: paso 11, imagen 3 de 3
    • Find the clips that hold the antenna onto the router.
    • Use one hand to push the clips in, while using your other hand to pull out the antenna. You may need to gently twist the antenna so it can separate from the hole.
    • The antenna may take considerable force to remove.
  12. NETGEAR WGT624 v3 Antenna Replacement: paso 12, imagen 1 de 1
    • Completely separate the antenna and wire from the rest of the device.
Conclusión
Equipo
Cal Poly, Team 3-31, Amido Winter 2013 Miembro de Cal Poly, Team 3-31, Amido Winter 2013
CPSU-AMIDO-W13S3G31
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 4,400
