Saltar al contenido principal
NEC LCD1770NX Capacitor Replacement
Qué necesitas
  1. NEC LCD1770NX Capacitor Replacement, Stand: paso 1, imagen 1 de 2 NEC LCD1770NX Capacitor Replacement, Stand: paso 1, imagen 2 de 2
    • Place the monitor face down on a clean, flat surface.
  2. NEC LCD1770NX Capacitor Replacement: paso 2, imagen 1 de 2 NEC LCD1770NX Capacitor Replacement: paso 2, imagen 2 de 2
    • Firmly remove the back panel of the stand by pulling it up and away from the monitor.
  3. NEC LCD1770NX Capacitor Replacement: paso 3, imagen 1 de 2 NEC LCD1770NX Capacitor Replacement: paso 3, imagen 2 de 2
    • Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
  4. NEC LCD1770NX Capacitor Replacement: paso 4, imagen 1 de 2 NEC LCD1770NX Capacitor Replacement: paso 4, imagen 2 de 2
    • Firmly grasp the stand enclosure with your hand and slide it to base of stand.
  5. NEC LCD1770NX Capacitor Replacement: paso 5, imagen 1 de 1
    • Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
  6. NEC LCD1770NX Capacitor Replacement: paso 6, imagen 1 de 2 NEC LCD1770NX Capacitor Replacement: paso 6, imagen 2 de 2
    • Lift the the stand straight up to remove it.
  7. NEC LCD1770NX Capacitor Replacement, Monitor Enclosure: paso 7, imagen 1 de 3 NEC LCD1770NX Capacitor Replacement, Monitor Enclosure: paso 7, imagen 2 de 3 NEC LCD1770NX Capacitor Replacement, Monitor Enclosure: paso 7, imagen 3 de 3
    • Place the monitor screen face up.
    • Pull the frame off by placing your fingers on the inside of the frame and pulling out and up, the frame should snap off.
    • Continue your way around the screen.
  8. NEC LCD1770NX Capacitor Replacement: paso 8, imagen 1 de 3 NEC LCD1770NX Capacitor Replacement: paso 8, imagen 2 de 3 NEC LCD1770NX Capacitor Replacement: paso 8, imagen 3 de 3
    • Unscrew the two 7mm screws from the bottom of the button assembly.
    • Do not pull the button assembly out too quickly or with too much force! Damage to the wires can occur.
    • Pull the button assembly out a few inches and unplug the colored cables.
  9. NEC LCD1770NX Capacitor Replacement: paso 9, imagen 1 de 2 NEC LCD1770NX Capacitor Replacement: paso 9, imagen 2 de 2
    • Unscrew the gold colored 7mm Phillips PH000 screw holding the button assembly to the monitor.
    • Remove the button assembly from the monitor.
  10. NEC LCD1770NX Capacitor Replacement: paso 10, imagen 1 de 1
    • With the monitor face-down, unscrew the 5 7mm Phillips PH2 screws around the outside of the enclosure.
  11. NEC LCD1770NX Capacitor Replacement: paso 11, imagen 1 de 3 NEC LCD1770NX Capacitor Replacement: paso 11, imagen 2 de 3 NEC LCD1770NX Capacitor Replacement: paso 11, imagen 3 de 3
    • Unscrew the 2 14.5mm Phillips PH2 screws located on the raised center of the enclosure.
    • Carefully pull the enclosure off the monitor.
  12. NEC LCD1770NX Capacitor Replacement: paso 12, imagen 1 de 2 NEC LCD1770NX Capacitor Replacement: paso 12, imagen 2 de 2
    • Unscrew the 10 5mm Philips PH2 screws holding the metal casing to the monitor.
  13. NEC LCD1770NX Capacitor Replacement: paso 13, imagen 1 de 2 NEC LCD1770NX Capacitor Replacement: paso 13, imagen 2 de 2
    • Pull the the metal casing off of the monitor to reveal the motherboards.
  14. NEC LCD1770NX Capacitor Replacement, Power Circuit Board: paso 14, imagen 1 de 3 NEC LCD1770NX Capacitor Replacement, Power Circuit Board: paso 14, imagen 2 de 3 NEC LCD1770NX Capacitor Replacement, Power Circuit Board: paso 14, imagen 3 de 3
    • Make a note or use a pen to mark which plugs correspond to which colors. (Pink or Blue)
    • Remove the four plugs on the brown circuit board by pulling up on the tabs and wiggling them out. You could also use a spudger to help you lift little clips holding them in.
  15. NEC LCD1770NX Capacitor Replacement: paso 15, imagen 1 de 3 NEC LCD1770NX Capacitor Replacement: paso 15, imagen 2 de 3 NEC LCD1770NX Capacitor Replacement: paso 15, imagen 3 de 3
    Herramienta utilizada en este paso:
    Large Needle Nose Pliers
    Comprar
    • Locate the several multi-wire connectors on the board.
    • These connect several parts of each board together and consist of several different colors of wires. There is also a zip-tie holding the two sets of wires together that you can cut if it is getting in your way.
    • Disconnect the three plastic connectors from the blue colored boards by pulling them up while wiggling them.
    • Some force is necessary, it may also help to use the Large Needle Nose Pliers.
  16. NEC LCD1770NX Capacitor Replacement: paso 16, imagen 1 de 1
    Phillips #1 Screwdriver
    $5.49
    Comprar
    • Locate the large black power plug.
    • Using a Phillips #1 Screwdriver, unscrew the two 8mm colts holding the black tabs to the metal frame.
  17. NEC LCD1770NX Capacitor Replacement: paso 17, imagen 1 de 1
    • Locate and remove the gold colored 10mm Philips screw located near the black power plug. It holds in a wire that connects to the power plug.
  18. NEC LCD1770NX Capacitor Replacement: paso 18, imagen 1 de 2 NEC LCD1770NX Capacitor Replacement: paso 18, imagen 2 de 2
    • Remove 5 8mm Phillip1 screws, with a Philips 1 screwdriver, located in various places on the board.
  19. NEC LCD1770NX Capacitor Replacement: paso 19, imagen 1 de 2 NEC LCD1770NX Capacitor Replacement: paso 19, imagen 2 de 2
    • Lift the brown power supply board off of the frame and set it aside.
  20. NEC LCD1770NX Capacitor Replacement, Capacitor: paso 20, imagen 1 de 1
    • Find the faulty capacitor on the board.
    • Bad capacitors can be identified by swelling or bursting at the top.
  21. NEC LCD1770NX Capacitor Replacement: paso 21, imagen 1 de 1
    • Flip the board over and find the corresponding solder joints. Capacitors have two joints on the opposite side of the circuit board.
    • Make sure you identify the correct solder joints! We wouldn't want you to desolder the wrong component!
    • Remember which direction the white stripe on the capacitor is facing! Orientation is important for a capacitor! The markings on the board should also remind which way to face the capacitor.
  22. NEC LCD1770NX Capacitor Replacement: paso 22, imagen 1 de 2 NEC LCD1770NX Capacitor Replacement: paso 22, imagen 2 de 2
    • Use a Soldering Station and Desoldering Braid to remove the solder from the two joints.
  23. NEC LCD1770NX Capacitor Replacement: paso 23, imagen 1 de 2 NEC LCD1770NX Capacitor Replacement: paso 23, imagen 2 de 2
    • Remove the capacitor from the board, you may need to straighten out the leads before you can take it out easily.
Conclusión
Charlie Mohr
Miembro Desde 10/21/13
353 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 11-36, Amido Fall 2013 Miembro de Cal Poly, Team 11-36, Amido Fall 2013
CPSU-AMIDO-F13S11G36
5 Miembros
7 Guías creadas
Un comentario
Hi, the content was comprehensive. Please comment on the electrolytic capacitor . Thank you.
fc fcbuy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 15
Todo El Tiempo: 1,055
