Saltar al contenido principal
NABI XD Rear panel Replacement
Qué necesitas
  1. NABI XD Rear panel Replacement, Rear panel: paso 1, imagen 1 de 2 NABI XD Rear panel Replacement, Rear panel: paso 1, imagen 2 de 2
    • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
  2. NABI XD Rear panel Replacement: paso 2, imagen 1 de 1
    • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
    • Go around the NABI XD and separate the rear panel from the device.
Conclusión
Equipo
USF Tampa, Team 17-2, Blackwell Fall 2016 Miembro de USF Tampa, Team 17-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G2
3 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 212
