Saltar al contenido principal
NABI XD Battery Replacement
Qué necesitas
  1. NABI XD Battery Replacement, Rear panel: paso 1, imagen 1 de 2 NABI XD Battery Replacement, Rear panel: paso 1, imagen 2 de 2
    • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
  2. NABI XD Battery Replacement: paso 2, imagen 1 de 1
    • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
    • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
    • Go around the NABI XD and separate the rear panel from the device.
  3. NABI XD Battery Replacement, Battery: paso 3, imagen 1 de 2 NABI XD Battery Replacement, Battery: paso 3, imagen 2 de 2
    • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
  4. NABI XD Battery Replacement: paso 4, imagen 1 de 1
    • Battery is glued to the base, lift carefully.
    • To remove battery, lift the battery up from the motherboard.
Conclusión
Equipo
USF Tampa, Team 17-2, Blackwell Fall 2016 Miembro de USF Tampa, Team 17-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G2
3 Miembros
12 Guías creadas
Un comentario
Where can you get the battery?
Dave - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 804
