Saltar al contenido principal
N-Strike Nite Finder EX-3 Battery Replacement
Qué necesitas
  1. N-Strike Nite Finder EX-3 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • The batteries are located in the handle of the blaster.
    • The base plate is held in place with a single phillips head, 8.2 mm screw. Remove this screw and remove the base plate to access the battery compartment.
  2. N-Strike Nite Finder EX-3 Battery Replacement: paso 2, imagen 1 de 1
    • Once the batteries have been removed, you can check to see if they have any charge left in them with a battery tester.
    • If they are in fact dead, replace them with standard AA type batteries in the correct orientation.
Conclusión
Equipo
Michigan Tech, Team 5-8, Lauer Spring 2014 Miembro de Michigan Tech, Team 5-8, Lauer Spring 2014
MTU-LAUER-S14S5G8
3 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 12
Todo El Tiempo: 2,666
