Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
MusicAngel JH-MD04E2 wired speakers Disassembly
Qué necesitas
  1. MusicAngel JH-MD04E2 wired speakers Disassembly, First assessment: paso 1, imagen 1 de 3 MusicAngel JH-MD04E2 wired speakers Disassembly, First assessment: paso 1, imagen 2 de 3 MusicAngel JH-MD04E2 wired speakers Disassembly, First assessment: paso 1, imagen 3 de 3
    • Bottom side has 4 5.95mm tapping Phillips #1 screws, under a rubber cover.
    • Under the label, there are two more Phillips #1 screws 9.15mm tapping screws.
  2. MusicAngel JH-MD04E2 wired speakers Disassembly, Opening the speaker: paso 2, imagen 1 de 3 MusicAngel JH-MD04E2 wired speakers Disassembly, Opening the speaker: paso 2, imagen 2 de 3 MusicAngel JH-MD04E2 wired speakers Disassembly, Opening the speaker: paso 2, imagen 3 de 3
    • Use a very thin metal prying tool and slide it in between the metal looking grill and the speaker body. Carefully pry it out (no glue is used) all the way around.
    • Repeat on both speaker sides.
  3. MusicAngel JH-MD04E2 wired speakers Disassembly, Taking out the parts: paso 3, imagen 1 de 3 MusicAngel JH-MD04E2 wired speakers Disassembly, Taking out the parts: paso 3, imagen 2 de 3 MusicAngel JH-MD04E2 wired speakers Disassembly, Taking out the parts: paso 3, imagen 3 de 3
    • Use a spudger to pry the battery that is glued to the top, from the body. Note: This is pretty strong adhesive.
    • Tilt the speaker grill / element a little, to slide it through the body.
  4. MusicAngel JH-MD04E2 wired speakers Disassembly, Information: paso 4, imagen 1 de 3 MusicAngel JH-MD04E2 wired speakers Disassembly, Information: paso 4, imagen 2 de 3 MusicAngel JH-MD04E2 wired speakers Disassembly, Information: paso 4, imagen 3 de 3
    • As you can see, there are no connectors used. All connections are soldered directly to the board.
    • No information can be found on the battery, either side.
    • The speaker elements are 45mm, 3W and 4Ω
  5. MusicAngel JH-MD04E2 wired speakers Disassembly, Board overview: paso 5, imagen 1 de 1
    • Not really much going on on this board.
Conclusión
2 personas más completaron esta guía.
Geir Ove Andersen
Miembro Desde 06/06/22
8,352 Reputación
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 25
Ultimos 30 días: 59
Todo El Tiempo: 581
