Saltar al contenido principal
Munchkinz Speaker Replacement
Qué necesitas
  1. Munchkinz Speaker Replacement, Opening Device: paso 1, imagen 1 de 1
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
  2. Munchkinz Speaker Replacement, Pry Device Apart: paso 2, imagen 1 de 2 Munchkinz Speaker Replacement, Pry Device Apart: paso 2, imagen 2 de 2
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
  3. Munchkinz Speaker Replacement, Separated Device: paso 3, imagen 1 de 1
    • After prying the device apart, it should look like this.
  4. Munchkinz Speaker Replacement, Pry Speaker: paso 4, imagen 1 de 2 Munchkinz Speaker Replacement, Pry Speaker: paso 4, imagen 2 de 2
    • Use the slim plastic opening tool to remove the speaker from its position on the case.
  5. Munchkinz Speaker Replacement, Locate Wires: paso 5, imagen 1 de 1
    • Locate the red and black wires that connect the speaker to the motherboard.
  6. Munchkinz Speaker Replacement, Solder Wires: paso 6, imagen 1 de 1
    • Un-solder the red and black speaker wires that are connected to the motherboard
Conclusión
David Wood
Miembro Desde 02/05/15
440 Reputación
4 Guías creadas
Equipo
UW Tacoma, Team 3-6, Rose Winter 2015 Miembro de UW Tacoma, Team 3-6, Rose Winter 2015
UWT-ROSE-W15S3G6
3 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 156
